FixYa.com
Tags:
Audio Shelf Systems
Generic problem for all Audio Shelf Systems
Disc Player not working (by 21 users)
posted by enihsnus on Oct 06, 2007
Hello
My sharp is running through all the 5 disc's and then when it is done it's saying "no disc" in the end.I cannot stop it from running through every one of them. I have tried many cd's and have "reset" the player but it still won't read them. I purchased and used a lense cleaner to no avail.I have not used the player much but it has sat unused for about a year.Can anyone help?
Thanks
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
20 Other Users Have The Same Problem
Comment by sterodummy, posted on Jun 30, 2008
cleaned the cd lens ----- tried diffent cd etc. power off and on and tried to reset
Comment by LATINGIRL, posted on Jun 16, 2008
I a Sony MCH-EC55 self system with 3 cd when i put to play 1 cd it skips to 2 when it keeps skipping then it says it has no cd when it has 1 2 or even three HELP ME
Comment by bobby brooks, posted on May 01, 2008
My RCA RS 1285 Gives me a no disc message. I opened up the unit and could get it to work by giving the disc a spin. It seams that the jaws are not grabbing the disc correctly. Is there an adjustment??
Comment by Guest, posted on Apr 22, 2008
I have the same problem. I used the manuals reset direction,but it does not work.
Comment by scooterdoc, posted on Apr 20, 2008
Mine just spits the disc back out :(
Best Solution
posted on Dec 07, 2007
FixYa! (100)
For Pets
Rank:Apprentice Apprentice
Rating: 85%, 8 votes
Please notify me when, and if, there is a solution. Thanks
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Oct 08, 2007
FixYa! (100)
dukic
Rank:Wiz Wiz
Rating: 83%, 101 votes
Maybe it's dust & dirt on laser lens, and lens cleaner can't help. You should try to clean it with some alcohol and cotton.
Solution #3
posted on Jan 05, 2008
FixYa! (100)
Capt Bob
Rating: 94%, 8 votes
This didn't work for me on my GE Spacemaker but it has worked on other cd players occasionally. The slide that the laser eye is on can be forced to move with a tooth pick or other tool. Just move it about a quarter of an inch without touching the eye itself and then try a disc again. You can't hurt it if it's broken already!
Solution #4
posted on Dec 16, 2007
Inappropriate (40)
Guest
Guest
Rating: 0%, 0 votes
How to fix the white pices
Solution #5
posted on Jun 22, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Came here to find a solution for my used, dirt cheap Sharp CDC 2600 3 disc changer "No Disc" error message. Discs would shuffle through the player before the error message was displayed.
Solution: I noted the pick up mechanism and laser were trying to read the outer edge of the disc, not the center. I then removed the disc tray and adjusted it so the laser read the center of the disc. Problem solved. Works fine now.
Solution #6
posted on May 27, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
clean the laser lens with a cotton Qtip, if not solve turn clockwise the trimpot at the laser module only 5 degree
Solution #7
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Hate to be stupid, but what slide the laser eye is on?
I did try the alcohol wash, to no avail. Maybe it is just worn o ut, but it is only about 2 yrs. old. Thanks for trying.
Solution #8
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
enlever le boitier puit le plastique du presseur de disque prendre un q tip avec alcool sur la lentile du laser nettoyer le tout voila ca MARCHE
Solution #9
posted on Dec 29, 2007
Not Rated (0)
Soulvisitor
Rank:Guru Guru
Rating: 88%, 1321 votes
This model contains a Cheap Poor Disk changer mechanism that goes out of time, gears slip and mechanism gets lost, if one was repairing this item one would quote replacement of cd changer assembly which would cost more than machine is worth not that i can even find replacement parts for it.
Barring replacement you would set aside a day, buy the service manual, and remove covers then remove the fantastic plastic cd changer, then you would take pics so you know how it goes back together, and strip it of its mechanical parts, clean them ( you will find hair/dust stopping and misguiding the plastic parts from a smooth operation), grease with plastic grease, clean switchs and reset to home position, reassemble it, only to have it do it again another time. Poor designed stuff, not made to last I'm afraid.
Link to purchase service manual
These sold from $200 to $60 bucks so what does one expect, they are cheaply made, here is link to another lot of people with same problem, stop spending time and money on it, they are not worth the time nor frustration. It can never be fixed, you may get it going, but again it will break
If your really really desperate to make it work, spray the darn thing like a bug with W.B. 40/Compressed air/contact cleaner, run a few cycles and try your luck.
Sorry no magic fix from here, just trying to tell it as it is.
This Problem Also Relates To: Rio EX1000 CD Shelf System Sony MHC-GX45 CD Shelf System Sony MHC-NX3AV Shelf System GPX HMW-9815CNP Shelf System Sony MHC-RV777D 220 Volt Hi-Fi Music System Shelf System Sony PHC-Z10 CD Shelf System Sony MHC-GX8800 CD Shelf System
Can you Help with these Audio Shelf Systems problems?
Bose SoundDock Digital Music System for Apple...
I can't get open the remote.
We bought this ages ago and... Answer This...
Sony MHC-GX450 CD Shelf System
my volume is messed up
when i turn on my volume, 11 is... Answer This...
Audio Shelf Systems
giga juke
cant get the wireless part of... Answer This...
Audio Shelf Systems
AIWA Xr M6 C.D player won't...
Hallo can you please advise?... Answer This...
JVC HX-D7 DVD Compact Stereo Audio / Video...
hxd7 protect
hi i am have the same problem... Answer This...
20 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Apr 20, 2008
Mine keeps spitting the disks out, I put the disk in and it chucks it back out as if it's the wrong way round :(
Comment by Crew Chief, posted on Mar 31, 2008
I'm having the same problem; CD's will not load it checks all five then states that there is no CD installed, this started as occasionally it would skip a disk now it's all five. I tried to run a disk cleaner CD but that also would not load, i have no idea how to get to the lens to try to clean it. Everything else still works. Any help would be appreciated.
Comment by Lcross, posted on Jan 11, 2008
Player won't read the discs. Have tried the same techniques. Still does not solve the problem.
Comment by jocksprocket, posted on Jan 08, 2008
the sharp xl-mp150 of mine has this fault, it will not read a cd, it always says no cd...Help....please resetting and turning off dont help, is it in need of a clean?
Comment by cdplayerdead, posted on Dec 18, 2007
I'm having a problem with the CD player not recognising any discs in it and displaying "NO DISC", are there any easy solutions? Have tried to insert lens cleaning disc, but still won't read it
Comment by Guest, posted on Dec 14, 2007
I have the same problem:(
Comment by For Pets, posted on Dec 07, 2007
My problem is just exactly like the others.
Have a JVC CD, radio and cassette player. Put the Cd's in - have tried one, two and three. Doesn't matter. In a minute, it tells me there are no CD's there. Can anyone help? Have tried cleaning the unit and nothing seems to help. Thanks
Comment by Guest, posted on Dec 07, 2007
I am having the same problem as several others.
Have a JVC stereo/radio combo. Put three discs in and it goes through all 3, in about a minute and then tells me there are no discs in the player. Can anyone suggest anything, other than throwing it out of the window?
Comment by Guest, posted on Dec 06, 2007
I have the MCD702. I insert a CD, player attempts to LOAD, ends up saying "NO DISC" even though there is a CD in the player. Tuner works, as does the Auxiliaries. Tried compressed air on the lens, will try swabbing with alcohol.
Comment by Guest, posted on Dec 05, 2007
Can't get the CD player to work consistently. Sometimes it plays but ususally does not.
Comment by Quanda, posted on Dec 05, 2007
Having same problem...Can you please tell me how to open the unit to access and clean the laser lens? Thanks.
Comment by Stamperone, posted on Dec 04, 2007
Will not read discs, have used disc cleaner , still reads no disc
Comment by SILLY D, posted on Dec 02, 2007
Every component works on my stereo, the only thing ids the cd player, as soon as you pu the cd in the tray it closes, then it says reading, but in actuallity it's not reading, 'cause it's not making the noise when the cd is being lifted and read or spining. Then it just says "NO DISK". someone please help, we bought a cleaner with the brush on the disk but it didn't work. It's a good stereo and has not been used in about 7 months, would like to fix the problem, but not fix it and pay more then it's worth.
Comment by Guest, posted on Nov 28, 2007
all components work except cd. i have tried a lens cleaner, but to no avail. when i try to play any disc, it looks like it is starting to read but then the display jumps to the 10th or 12th track, no sound
Comment by BISBEE, posted on Nov 08, 2007
THE CD SHOWS NO DISK THEN IT WILL TURN TO READ AND NOTHING PLAYS CHANGE CD DOENOT HELP OR RESETTING DOESNOT HELP
Repair Service
Find Audio Shelf System Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
