Question about Maytag MES5870A Electric Kitchen Range
Oven and range not getting hot
I just recently purchased this range from a friend. It was working perfectly. Now it takes an hour to boil water, and it doesn't even get to a rolling boil. Also it took over an hour to get the oven to 350. I've checked and I'm getting 240 to the back of the range so I'm not sure what else to do. Thanks
6ya staff
SOURCE:
dcp2
Daniel Phillips
  • 63 Answers
SOURCE: Oben takes half an hour to heat up
I doubt its the igniter. It could be a faulty gas valve or maybe the orifice is blocked, and not letting enough gas into the burner
Posted on Jan 28, 2008
seakish
  • 492 Answers
SOURCE: Oven lights, but temp does not get above 100
The gas burner is broken. There is an upper burner and a lower burner. In-order for both burners to turn on, both must be working to let the gas turn on. If one burner element is out the oven wont get hot just warm.
Posted on Apr 30, 2009
EllaWatson25
Ella Watson
  • 725 Answers
SOURCE: I have a maytag gas range. The oven is taking up
Your t-stat is out on this model. This is a simpe repair that you can do yourself and save alot of $$$$$$!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service with brand and model number and we will get the correct part out to you asap.
We hope to get you cooking again real soon.
Thanks, Ella
Posted on Nov 11, 2009
EllaWatson25
Ella Watson
  • 725 Answers
SOURCE: Lower oven does not get hot.
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
Posted on Mar 11, 2010
BarrettDenCo
Barrett Palumbo
  • 1772 Answers
SOURCE: I have a Maytag Gemini
Sorry to read about your problem, I hope this helps you out.
OVEN TEMPERATURE ADJUSTMENT
If you think the oven is operating too cold or hot, you can adjust it. Bake several test items and then adjust the temperature set- ting not more than 10° F at a time.
To Adjust: 1. PresstheBAKEpad(upperorlower
oven) and enter 550° F.
2. PressandholdtheBAKEpad(upperor lower oven) for several seconds until TEMP ADJ is displayed.
3. PresstheAUTOSETpad-eachpress changesthetemperatureby5°F. The control will accept changes from -35° to +35° F.
4. Iftheovenwaspreviouslyadjusted,the change will be displayed. For example, if the oven temperature was reduced by 15° F, the display will show -15° F.
5. When you have made the adjustment, press the CANCEL pad and the time of day will reappear in the display. The oven will now bake at the adjusted temperature.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 24, 2010
Recently purchased Candy gov58f. Placed in outhouse/garage. Will not start and continue to run necessary to stand with machine and keep re starting 2 or 3 times until runs .contacted engineers they say...
I have had the same problem. I contacted Candy who had had over 2000 calls this week about this. Place a pan of boiling water (still in the pan) in the machine for half an hour and then it will work. Apparently it is frozen! Hope this works for you too x
May 17, 2010 | Dryers
Older ge spacemaker range, temps wont boil water on stovetop, oven takes hours to hit 300 degrees could it be wiring or thermostat? says pn PLT135-3 owners manual [dont have] PLT059-2 model number...
Check your breakers to the oven. It sounds like one of the two of them have tripped and you are only getting 120 VAC.
Do you have a volt-ohm meter, and know how to use it?
Dec 18, 2009 | GE Spacemaker JMP28 Electric Kitchen Range
We purchased a Frigidaire cooker, electric oven, propane gas hob. It seemed odd that the hob rings take ages to boil a pan of water, cooking with oil is extremely difficult as it takes way too long to get...
Is this a mistake? It's impossible that nozzles didn't helped...? Just impossible.
Or was this problem posted before our chat session..?
Either ways Do Not hessitate to Contact us on fixya
Good luck with your cooker, and HAVE A NICE DINER
Jun 24, 2009 | Microwave Ovens
Burnt sugar caramelized on a Jenn-Aire glass cook top
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
This stuuf really works
Mar 14, 2009 | Jenn-Air JJW8230D Electric Double Oven
Model WHIRLPOOL WEP54800 Stove starts to beep at differnt times of the day.After four beeps F2 showes up and continues to beep when it feels it should. The control board has been checked twice and A new...
Hello fairglen,
welcome,
You said, model WHIRLPOOL WEP54800 Stove starts to beep at different times of the day.After four beeps F2 shows up and continues to beep when it feels it should. The control board has been checked twice and A new oven sensor installed. EVERY thing works perfect.This all started after water was brought to A boil on the back burner
But something is wrong!!??
Check your model number.
It is not showing up anywhere in the repair manuals or error codes.
Not even Canada.
What country did you buy it in?
How old is this range?
These are the only F2 codes I found in whirlpool so far!
F2 - Oven temperature sensor shorted = Replace oven temperature sensor
F2-Oven temperature above specifications = 8-pin connector oven temperature sensor to the Electronic Range Control (ERC)
Waiting your response or correction!!!!!!!!!!!
Huuum
Oct 17, 2008 | Whirlpool Kitchen Ranges
Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Mar 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
The grease drain line is clogged on my Jenn Air Range/Oven somewhere between the grease storage bin and the bottom of the grill area in the area that is not visible. Is it possible to clean this?
Both grease drain lines on my Jenn Aire SVE 47600 are blocked - I have tried liquid plumber, but it hasn't cleared things up. Has anyone had this problem and figured out a solution?
Jan 13, 2008 | Kitchen Ranges
Stove/oven gets hot then shuts off
Shut the breaker off! These are the exact symptoms that a tenant of ours reported for their range. I went to check the range and found that one of the power wires on the terminal block in the back of the range was burning itself up. It had actually started a small wire fire. You need to pull the range out of it's hole and unplug it. Remove the panel in the back above where the cable goes into the range. Examine the power wires and terminal block carefully, because I bet you'll find one of the wires is burning up and needs to be repaired. Please write back and let know what you find.
Aug 09, 2007 | Frigidaire FES367 Electric Kitchen Range
Range
On your oven, look in your manual and you can calibrate the oven +/- 35 degrees.If it is out of the range of calibration then replace your oven sensor or themostat which ever one you have.On your fridge I would recheck your drain hose from both ends and puor boiling hot water down drain.The only 2 reasons why you would have water on bottom of fridge is 1 a water leak or cloged drain.good luck
May 25, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Maytag MES5870A Electric Kitchen Range Logo
27 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
