Question about Rio Forge Sport Digital Media Player
Battery problem My player was working fine and then all of a sudden, it stopped and everything stiffened up...all the keys. When I took out the battery I saw it had almost melted the player where the battery had been. Of course, it doesn't work. I don't think it's repairable, but I don't know if it's a flaw with the player.
  • 363 Answers
It sounds like the battery was short circuited. You were lucky there was no fire. It's possible there was a flaw with the battery. If this was a rechargeable Lithium Polymer battery then you might remember these were in the news recently because lots of laptops were bursting into flames. Also a friend of mine had one of these in his remote control plane. After he finished flying one day, he left the battery on charge in his BMW from the cigarette lighter while he went shopping and when he returned the fire brigade were putting his car out!
Posted on Oct 06, 2007
SOURCE:
My 1999 Toyota Rav, while driving, suddenly became difficult to steer...the peddles also stiffened up. The engine then cut off and the lights came on. Suggestions?
Difficult to steer:Possible power steering belt failure.
Bad alternator? Check voltage at battery.Needs at least 12 V. to enguage starter. Try jumping the battery from another vehicle.
May 19, 2014 | Toyota RAV4 Cars & Trucks
No Electrical power on my 05 V10 Ford Super Duty
The fact that you have disconnected the battery for a month without any form of charghing is risky, as batterries that have been used for a long time and then suddenly disconnected go flat quickly especially in winter or cold months. Have you checked your batterie's voltage to see if it is not flat? Do so if not.The little bit of current left in the batterry will be enough to switch on the CD player's lights as these are merely LED's which only need about 1 to 1.5 volts to work and this is why everything else that uses larger voltages does not work.
Apr 15, 2013 | 2005 Ford F 250 Super Duty
The remote control on our Toshiba SD-690KA player has stopped working. Replace batteries... still not working.
Took the batteries out... pressed each button on the remote individually... put batteries back in. It works fine now.
Jan 21, 2010 | Toshiba SD-690KA Player
My "t" and "y" key randomly will not type
You could try using compressed air to move your lunch and dust/dirt from under the keys
Sep 05, 2009 | HP Pavilion dv6000z Notebook
Evo 8 stirring wheel stiffens in sudden speed then sudden brake..
i think your car has a shut down senser for the motor.as for the stiring never heard of that problem. it coul be part of the shut down senser
Jun 11, 2009 | 2006 Mitsubishi Lancer Evolution
Remote key lock stopped working after wal mart put new battery in and now my head lights stopped workin!!!
check fuse for low beam, then possibly both low beam globes. they could have blown.
the key remote may need reprograming into system try put key in ignition in on position then press remote buttons a couple of times then try if no good need to go to dealer to be programed into system again or it needs repairing/replacing.
May 31, 2009 | 1996 Chevrolet Camaro
Motorola SLVR L7 not vibrating
When you are charging a phone you are not supposed to leave it on vibrate, for whatever reason-it damages the phone. My suggestion take the battery out with the power still on then try and turn it on again. If that doesn't fix it your ******** is shot. You may need to replace your phone. Sorry your having trouble, hope I helped!!
Mar 19, 2009 | Motorola Mobility SLVR L7 Cellular Phone
KW-NX700, constant "lost gps signal" all of a sudden!
Hi,this problem exist because the navigation is bloqued, if reset the problem is the same.
The solution for this problem is:
desconect de battery car, and wait 15 minutes
conect the bactery, work`s fine
cumps
Luis Gabriel Portugal
Lutrónica
Dec 12, 2008 | JVC KW-NX7000 Car DVD Player
Touchpad won't work on my Gigabeat F40
Mine did the same, touch pad became erratic then stopped working, I could still access everything when linked to a computer. Then all stopped, on power up I got a 00000010 or 0000020 error and nothing.
I popped the end caps off, removed the two small screws holding the back on and found the strap of wires connecting the hard drive was almost completely dissconnected. Pushed the connector back together , reassembled and now all working
Apr 26, 2008 | Toshiba Gigabeat MEGF40S MP3 Player
TV not working
My 32" Akai did the same thing. It was working fine, I tried everything but nothing worked. Took it to a reapairman and it was the power supply. He said that they were very known to have this problem. I had the system attached to a UPS battery backup and it made not difference.
Mar 30, 2008 | Televison & Video
Open Questions:
Rio Forge Sport Digital Media Player Logo
52 people viewed this question
Top Rio Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
