The solution to reset the display was: Control, Alt, UP Arrow at same time. The solution to reset the display was: Control, Alt, UP Arrow at same time.
You can't post conmments that contain an email address.
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Probably not the monitor but a software issue. Depending on what OS/graphics driver you use you can rotate the screen. I would need to do is find the setting and rotate it back to normal. For instance if you are using XP and integrated intel graphics you can right click anywhere on the desktop area, left click on graphic options and rotate 90, 180, or 270 degrees. If you run NVIDIA you can right click on your desktop area and click on NIVIDIA control panel. From there find rotation settings and choose what you need to return your display to normal.
On the bottom right of the usual desktop display there you should find a Nvidia green logo, to set Nvidia settings.
Right click on the green Nvidia Settings logo and put your mouse over Screen Rotation.
Select the option to set screen rotation to 0 degrees.
The other way is to go to the control panel and double click on Nvidia Control Panel and select Rotate Display.
Ensure that it is set to 0 Degrees/ No rotation landscape
Hope this puts it the right way up!
All the best!
damnor01
If you have an Nvidia Graphics card then on the bottom right hand side of your task bar, next to the time, it's a green icon. A Nvidia logo is displayed. Left click on it and move your mouse over rotation settings, should be set to rotate 0 degrees.
Can also access through control panel, then Nvidia control panel, then on the left menu rotate display, set it to no rotation 0 degrees.
Please take the time to rate my expertise.
Thanks
This is a feature of a number of display drivers and is usually enabled by a combination of keystrokes, try control+shift+R or control+shift+cursor key. Look at the display properties by right clicking on an empty part of desktop and look for any options to untick there, usually under settings; advanced.
You may try CTRL-ALT- and one of the four arrow keys. Usually CTRL-ALT-DOWN ARROW solves most of them, but it depends on which way the image is rotated.
Perhaps your connections on the inside have come loose. It may warrant you take it to a specialist to check it over before it gets any worse. Some other person was on here some time ago who had a similar problem and all it was is the switch in the lid. Apparently they tinkered with it by just kept on pushing it back and forwards as if to continue to open it and it came right they tell me that they hardly used it thats why!.
