SOURCE: vhs pal video not working
Change the DIP switch to PAL, unplug the unit (no power), then plug it back in. You need to power-cycle the unit to after changing DIP switch settings.
Also make sure that your capture application is set to PAL mode, if there is a NTSC/PAL setting.
SOURCE: PAL Problem and ADVC110
It's difficult to tell what's really going on by looking at the PC monitor. You should generate a DV file and play it back through the ADVC to a TV and see.
The issue is interlacing. Since the two fields of interlaced video are originated at different points in time, when you play both fields on a non-interlaced display like a PC monitor, you see the two combined and they don't match up. So you get half of a ball before the line, and half of the ball after the line and it looks funny.
SOURCE: Canopus ADVC110
Yes you can. I have that very same setup using a surveilance cam as my webcam =)
Yawcam is a pretty good allround webcam application with lots of features, I recommend it!
