Question about iRiver H340 MP3 Player
Short Circuiting Hi, when i am listing to my iriver h340 40 gig all of the sudden it shuts off,when i turn it on again it says low battery and turns off even when i have charged the battery all night and i have full power!
  • 2 more comments
  • touchwood Nov 04, 2007
    Hi I purchased a H£40 player three years ago and it was working fine for a good year and I really got to like ny iriver. I got a link to upgrade my firmware to the newest version via a Korean like It worked well and enabled me to run video files which it did not do before the upgrade. But shortly after I got the same problem you mention. Whether the battery got a drain upon needing to run video files maybe it was too much strain on the battery. But if you or anyonlse has an answer to this do let me know I may need a new battery. cheers Touchwood1064
  • h340user Nov 12, 2007
    My H340 charges very, very slow (needs about a week), wether I use the original firmware or rockbox which was running fine for over 2 years. Replacing the battery did not help. I will go to measure the charging current, the voltage seems to be o.k. (would not charge at all otherwise). I used a spare charger, but that did not help. Any suggestions?
  • d213407 Jan 17, 2008
    I have the same issue it seems, when i am listing to my iriver h340 40 gig all of the sudden it shuts
    i know the battery is fully charged from the cradle. The charging time has not differed to any real degree from when it was new. Its now about 2.5 years old.
  • frankiriver May 30, 2008
    I have a h340 40G bout 2-3 yrs old, exactly same as matthew2293, plays music ok then suddenly dies, you switch it back on and it either dies again straightaway, or I get 'low battery' message then it goes off again or it works for a very short while then dies again, all even though it is just fully charged and the battery indicator shows full power. Thought I would try upgrading my firmware to the latest as recommended on th Iriver website but..... the latest they are currently offering is 1.29EU when I already have 1.30E many months ago? Where and when did this firmware go from the Iriver website?
I had the same problem. Change the battery, its like having a new iRiver.
Posted on Mar 08, 2008
Sounds like you need to Replace the battery
Posted on Dec 29, 2007
SOURCE:
Westinghouse dishwasher SB908 short-circuiting power board
Your symptom is a little confusing, it's best to post a complete model number as written on the ID tag of the unit. This will help to provide better information. PLeazer Appliance...
Jan 14, 2015 | Westinghouse Dishwashers
2001 R6 press the electric tart button and it buzzes
hi...
der may b several reasons
1. charge in battery may b low so try t after changing the battery
2.der may b some short circuiting occuring wen u press the start button
3.the is too much load on the starter motor which wen starting current in more picks up and gradully reduces its speed.
4.motor insulatioin may be gone so short circuiting may occur inside motor.
so plz check all these things...
Jul 04, 2010 | 2000 Yamaha YZF-R6
Iriver h10 when switch on it shows system file missing connect h
I'm not sure my solution can help you or not.
I've got this message too but after I formated H10 by Windows.
First backup all files by window explorer.
Open iriver plus and go to > Option > Portable Device Initialization.
This function will delete all data, Please sure that you already backup all of your data from H10.
After initialize process finished, it will ask you to disconnect and connect it agian.
------ Steps below, I can't explain it clearly. May be you will not have the same results as me. I hope it can rise you some ideas how it comes.
I followed that instruction but after I disconnected it again and turned on, expected that msg will disappear, IT's NOT! a bit freak out.
Ok claim down,
I tried to turn it off but I can't then I pushed its battery out and put it back and turned on, that msg showed up again.
Then I connected H10 to Iriver plus again and it upgrades firmware automatically.
At the end after I disconnected and turn on my H10 it works perfectly.
I'm not a native English so my language could make you confused, any questions you can contact me. :)
Jul 16, 2009 | iRiver H10 MP3 Player
H300 battery after being charged lasts about 15 minutes tops
buy a battery kit from the site underneath your question and install it yourself.I did this-cost $29 now my iriver h320 has anew life and is better than ever!
Mar 29, 2009 | iRiver H320 MP3 Player
IRiver H320 is completely dead
you can change battery and/or upgrade hard drive (if changing hard drive, save the software to pc then copy to new hard drive)
how to replace battery / hard drive
check and follow this link http://www.youtube.com/watch?v=6HOnpHSgMvw
if you dont have tools http://www.ipods99.com/Default.asp?Redirected=Y
Sep 18, 2008 | iRiver T20 MP3 Player
Iriver white screen
just reset the player by using paper clip on the hole and press down the player will turn off then try again......
if not you need the proper battery for your h320 iriver player....
Jun 29, 2008 | iRiver H320 MP3 Player
I plugged the USB cable into it and suddenly it now won't turn on at all
totally the same problem here and i still dont know what to do and from what i here, iriver support does nothing for you because it's a "known" problem
Oct 30, 2007 | iRiver T30 MP3 Player
Iriver h320 battery problems
your battery is broken you must buy new battery (very good battery is 2200 mAh because battery install in your iriver is 1350 mAh)
Oct 01, 2007 | iRiver H320 MP3 Player
Not again wont turn on
i had the same situation this happens when you dont turn off your t20 after you disconnet it from your pc IRIVERS T2O PROBLEM IS THAT IT AUTOMATICALY TURNS ON EVERY TIME YOU DISCONNET IT FROM PC AND IF YOU DONT TURN IT OFF AFTER THIS - IT FROZES it wont connect to pc after this happens so you have to wait ussualy (~12 hours) until the battery runs low, so after this has happened wait and then after some time try to press play button (to turn it on) and if the battery is dead - it will show LOW BATTERY sign and then you can connect it to your pc again normaly! hope this will help
Feb 28, 2007 | iRiver T20 MP3 Player
iRiver H340 MP3 Player Logo
103 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Ekse
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
