Question about Toshiba XB1507 Receiver
Can't get sound on the left front speaker
It dosent't work the left front speaker, I tried to change speakers and I still can't get sound on the left front speaker out
  • 93 Answers
Check fuse, if there is any.
Posted on Oct 08, 2007
Onkyo HT S3300 center, left front and rear speaker not working.
check your speaker wiring, make sure both terminals are connected properly. or could just be left speaker is disconnected. and is set in stereo mode which will only play left and right front and Sub, if you have one. try chaning the surround mode to play in multi channel speaker which will send sound to all speakers. i trust your using a Digital audio cable from your source ( cable box, DVD player) if your using analog audio cable you will only get stereo sound, and nothing will ever come out of the rear speaker unless you change the surround mode to multi- channel speaker. also in the setup menu you should be able to perform a speaker setup, make sure all your speakers are able to produce sound. follow speaker setup mode in menu, make sure you have checked the boxes or Yes to speaker you have in your system. then perform calibration and a test tone will come out of each speaker as you select them.
Apr 28, 2011 | Audio Players & Recorders
Surround sound speaker outlets are not working
Might be a loose connection problem. A contact cleaner is handy in cleaning the terminals. Try to swap the speaker connections if you don't have a multi-tester to check the resistance of the speakers. If the right front speaker will sound after connecting it to the left front speaker output, then it is a speaker coil problem. If not, might be an amplifier channel problem.
Jan 12, 2009 | Durabrand 5.1 Surround Sound Computer...
DVD plays partial sound
Check your speaker connections it sounds like you have a 5.1 or higher sound system. 5.1 means left front speaker, right front speaker, center speaker, right rear speaker, left rear speaker and subwoofer.
Voices in movies all get channeled to the center speaker (you can usually hear it a bit from the right and left front speakers as well). If your center speaker is disconnected or not working, you will only hear the background sounds.
Sep 20, 2008 | Compaq Presario 5000 PC Desktop
Front Right Signal to Front Left Speaker
It is a problem with mixing sound, DX9, or CMSS for 6.0 speakers, try reseting the creative diag. or change the PCI card on another slot.
1) verify connectors.
Jun 15, 2008 | Logitech Z-560 Computer Speakers
Left speaker not working...
hi, there's a big possibility that the issue you encountered in your speaker might be caused by a faulty or shorted wire. You can check it by inspecting for any sign of damage on the wire and try connecting your left speaker to a different input source.
Tirzo
Jun 14, 2008 | Harman Kardon HK19.5 Computer Speakers
Connect DVD Player to logitech X 540 Surround System
Bad connection on that one speaker, if you have tested the system with other equipment and it works thn you MUST have a bad connection INSIDE you DVD player. If your DVD had a whole channel out on your output amplifier I beleive then 2 speakers would not work so more than likely you have a bad solder joint inside system for DVD output
Feb 11, 2008 | Logitech X-540 Computer Speakers
Can't get sound throught one speaker
Did you get the solution for your problem? I am currently facing exactly the same problem. My front right speaker is not working when connected properly, but when I change its connections to left front, it is okay suggesting that there is nothing wrong with the speaker.
Murali
Sep 10, 2007 | Durabrand HT-3915 System
Speakers not working proprerly
This may be in the sound card settings itself. Even though you may have adjusted the Windows settings {if thats what your using} the sound card needs to also be set up for surround. Some sound cards do not support 4 speakers or surround sound systems. Go to Device Manager and find your sound card and manufacture then check there technical support page for info.
Sep 07, 2007 | Audio Players & Recorders
Surround Sound Center Speaker/Sound Card issue
You need to use a digital interface cable between the sound card and the speakers to get all of the 6 channels to work properly.
Sep 24, 2006 | Inland 58019 ThunderSound 5.1 PCI Sound...
108 people viewed this question
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
James DuPont Jr
James DuPont Jr
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
