Question about Garmin iQue 3600 GPS Receiver
Why will my Garmin not sync into my computer?
I have tried to sync my Garmin palm into the computer and it does not function. It says that it has failed. Why is this?
  • 5 more comments
  • jeannieju Dec 02, 2007
    I have just had a new hard drive installed, the technician installed some 'charup mirror' which did sync my garmin to Outlook successfully, but this was not desired. I want to re associate with Palm Desktop. I have uninstalled the 'char' thing, have installed palm desktop, but cannot get the hotsync to connect. Not sure how to know which 'com 1' or 'com 3' to select for usb hub?
  • kmsmith2010 May 09, 2008
    I have a Garmin nuvi 750 and it will not sync with my computer - Windows XP. I am hoping to transfer MP3 files and map information. I cannot find where my computer has recognized the Garmin via a usb.
  • RayNygren Jun 03, 2008
    The USB sync cable is not recognized. I have a full charge on the battery and the battery is also getting charged by the USB but it's not on the device driver list. I installed the latest software from garmen. you cant get to it directly but if you google you can get to the desktop 4.01 and the drivers. But for some reason the USB doenst trigger a load the drivers in XP or vista is there a manual process to load drivers? maybe try a serial cable?
  • FrankReuvers Jun 10, 2008
    Map install fails due to sync failure problem
  • taifok Jul 28, 2008
    I formated my hard drive and reinstalled the Palm Desktop. Everything seems okay except all the data at handheld ( address, memopad..etc) did not copied to the computer.
  • Anonymous Aug 19, 2008
    PDA: Garmin IQUE 3600
    Symptom: Hotsynch can be started from icon on PDA or button on cradle, but times out when it cannot find computer. It had been working but stopped some time ago.
    Notes: Cradle is plugged into USB connection. Hotsynch from this unit has failed on multiple computers, including a brand new computer during hardware/software setup using original install disks. Fails on two different cradles. Because the button on the cradle works, I know the PDA can find the cradle. Is it possible that there is a problem with the unit?
    Lisa
  • Anonymous Aug 28, 2008
    i Que 3600 will not hotSnc on my computer (XP Pro) but does on my old Pen III with same software and does on Lap Top with Vista. It says Com Port 1 is being used and as soon as it is free it will activate. (Which is never)
As one of the Garmin IQUE 3600 owners for so many years, and switched computers many times (yes, I am still actively using it), I would like to share my experience that I had with this sync problem (palm desktop running, press the sync button, but there is no sync "beep", and the sync will eventually timed-out).
My problem is solved by "timing" the sync. My set up is that hotsync will run only when the palm desktop is running. So afterI double-clicked the palm desktop icon, the hotsync icon in the system tray will show up first, and then the palm desktop will show up. I observed that if I press the sync button on the cradle right within few seconds after palm desktop shows up, the sync will likely to succeed. If I waited too long, my sync will not work. If it fails, I will exit palm desktop, wait for the hotsync icon to disappear and try it all over again. Good luck.
Posted on Aug 25, 2008
I get error2738, then fatal error, on my garmin 3600 ique, it won't sync
Posted on Jun 04, 2008
"guest" who said "that does not work" was not original poster, jeannieju. My problems were solved by Garmin tech support remotely accessing my computer and getting things working, back in November. But thanks for trying. I was surprised to see an alert in my e-mail. Jeannieju
Posted on Mar 01, 2008
  • 752 Answers
First, right click the hotsync button in the task bar and make sure "USB" is selected (assuming you're using USB...).
If that doesn't work, let me know.
Posted on Nov 08, 2007
SOURCE:
Hot sync problem for Garmin iQue 3600
If reinstalling on the same computer with your original cd doesnt' work then I suspect that your registry has gotten corrupted somehow.
I'd find another computer and try a totally new install to see if that works. This registry stuff is a headache.
If it works on a different computer then I'd go into the registry and remove all traces of Palm and ique and start all over. Always make a backup of your registry before messing around with it. If the original CD worked before then there's no reason to download newer versions unless you are wanting to solve some other problems.
Don
Jan 27, 2010 | Garmin iQue 3600 GPS Receiver
Garmin hotsync issue
Hey uninstall the program, download the newest one available and try again.
Sep 08, 2008 | Garmin iQue 3600 GPS Receiver
Copy Contacts from Palm Centro to SIM Card
When I migrated from my Palm Centro (best smartphone ever) to my current BlackBerry, I did the following: 1) Export Palm contacts from the Palm Desktop software to CSV (comma separated values or tab-delimited text) format. 2) Import the CSV file to your Google Contacts account. 3) Wirelessly sync Google Contacts to your new phone using the free Google Sync app (link below). 4) Verify data was transferred appropriately.
Google Sync details: http://www.google.com/mobile/sync/
You should be able to follow the same process for your Palm Calendar by exporting your Palm Calendar from the Palm Desktop software to a file (save the exported file to your desktop, or an easy to find location on your computer), then import the Calendar file into a NEW Google Calendar, not your primary calendar (in case there's conflicts or problems, you can delete the secondary Google calendar without losing your primary Google calendar items). Google Sync should allow you to choose more than one Google Calendar to sync with your new phone.
Dec 29, 2009 | Palm Treo 500 Centro
How do i tranfer my contacts from my palm centro & another palm centro?
First, make sure you backup all of your data, including data in any 3rd party apps.
Sync your first Palm Centro with the Palm Desktop software to save the data.
Verify the sync settings in the Palm Desktop software to make sure when you begin syncing with the new Palm Centro, the settings for each application (contacts, calendar, memos, etc.) are one-way sync to the device, or you might end up overwriting the data in your Palm Desktop software with what's on the new Palm Centro.
When you sync your new Palm Centro with the desktop software the first time it will ask you to name the new device. If you give it the same name as the old Palm Centro, all of the data will sync to your new Palm Centro.
Search your computer for a folder with the name "Palm" in it to try and locate the name of your old Palm Centro, so you can name the new Palm Centro the same. When you locate that folder on your computer, it would be a good idea to simply make a copy of that folder as a total backup.
Dec 22, 2009 | AT&T Palm Centro Cell Phone - White
IQue 3600 sim card problem
from Garmin:
Question: Why wont the PC recognise my the SD card in my iQue 3600?
--> Answer: Go to My computer and look for the following directory:
  • C: > Program Files > Palm > (user name) > file called 'sync'
  • Double click on this file and delete the four bottom rows that will look something like this:
"SlotId=0
MediaType=1935960423
DisplayName=SecureDigital (SD) Card
InstallDirName=Slot-SD"
  • Then try a HotSync as normal, it should then 'see' your SD card.
  • If all fails delete a second user name as sometimes this interferes.
Mar 14, 2008 | Garmin iQue 3600 GPS Receiver
Sync problems with windows vista
I got a Vista computer in April and have problems also. You need a special program to install the maps. email Garmin and they will send you the link. An SD card reader/writer is MUCH faster than the sync.
I didn't have syncing problems until after I tried to install Documents to Go. I had to remove Doc to Go v6 because it was making my computer unstable. Doc to GO V10 works with Vista but requires Palm OS6. Garmin says that Palm OS6 can't be installed on the Garmin iQue because they added proprietary software to OS4. I believe my sync problems will disappear after I reload the Palm Software.
Feb 18, 2008 | Garmin iQue 3600 GPS Receiver
Non-Garmin GPSr
Garmin software will only work with Garmin hardware. Garmin does not use the standard NEMA protocol for GPS output, but their own. Also their software is tied to their hardware by a unit id, which require an unlock code in order for the maps to function.
Jan 22, 2008 | Garmin StreetPilot c550 GPS Receiver
Palm M515 hot sync problem
I have a similar problem with my m515. I have 3 palms and 2 sync fine but the 3rd isn't even getting to the computer. There is no recognition from the computer that the palm is trying to sync even though I use the same cradle for all palms. The ensuing message is, "the connection between your handeld computer and the desktop could not be established. Please check your setup and try again". My settings are set Local and Cradle/Cable.
Dec 20, 2007 | Palm m515 Handheld
Syncing of palm times out
this is producers mistake :(
Sep 23, 2007 | Palm Treo 750 Smartphone
Lost calendar on hotsync
The information is unfortunately lost.
Unless you synced the palm on another computer, the palm only can back up the information when synced.
So if you sync it and the computer overwrites the handheld, the information never made it to the computer and thus cannot be restored.
The only thing you could check would be the backup folder in the palm directory under your profile name. Palm puts all of the .prc/.pdb files in there when you sync.
Sep 13, 2005 | Palm LifeDrive Handheld
Garmin iQue 3600 GPS Receiver Logo
2,309 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
