You really need a volt / ohm meter to check for Continuity & Volts Its well worth the investment... $15.00 bucks give or take a few
I would check to see if you have 220v to back of dryer where the cord mounts to dryer, If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat.
Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity.
I turn the start button and the dryer makes an awful clunky sound. The belt seems to be intact. I...
(More)
I turn the start button and the dryer makes an awful clunky sound. The belt seems to be intact. I just thoroughly cleaned out the lint trap and line running outside on Saturday and this problem occurred last night. Do you think I jiggled something loose?
