Question about Candy CPCA240FFK Bottom Freezer Refrigerator
Water leaking from freezer and fridge
For a while now we have had water leaking from under the freezer. Now the fridge seems to have water running down the back collecting in the bit at the bottom and instead of going out through the pipe it is dropping on to floor of fridge. outlet pipe is clear. any ideas.
  • 473 Answers
Need to see if the drain if frozen over. Will have to take back panel in freezer off to verify. This is usually the cause. If it is frozen over run hot water down drain until all ice is gone. If the defrost heater is close enough to the drain you can install what is called a heat probe that attaches to the heater and sticks down into the drain hole which helps prevent this problem.
Posted on Oct 06, 2007
SOURCE:
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
Side by side leaking water from under freezer side
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 15, 2009 | Hotpoint HSS25GFP Side by Side...
Water setteling on bottom of freezer side and freezing also leaking. 2 fridges both doing the same thing . leaking on the inside and freezing and underneath water is leaking.
Clean out the defrost drain. There is a drain in the freezer that lets all the defrost water run under the fridge. If that gets clogged then all the water runs into the freezer and can even leak onto the floor
Sep 13, 2009 | Refrigerators
Freezer leaking water
My Whirlpool has been filling the bottom under the crispers with water and leaking out the vents (?) from the freezer down into the fridge compartment. I finally caught it today being rather loud, probably in a defrost cycle, and it was positively POURING in the fridge. After some more research on this site I removed the freezer bottom tray (1/4" ratchet needed) and found a layer of 1/2" thick ice under the tray. My guess is the drain hole iced up. Removed all the ice from under the tray and on the metal drain run in the back (danger, seemed sharp) and put it all back together. I didn't try to pour hot water down the drain yet, thinking positive thoughts that the drain itself isn't iced all the way to the tray near the floor. Will watch it carefully.
Apr 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Whirlpool Fridge makes a loud dripping sound all the time G56SHE
Erin,
The water you hear sounds like it's coming from the automatic defroster in the freezer compartment. It runs down a drain tube into the pan you describe under the fridge. The pan is heated and evaporates the water.
Just some possible explanations if you are hearing "lots" of water"
* You may be in a warmer, more humid climate
* The temperature and humidity in your dwelling is elevated
* The door gasket on the freezer may be leaking
* The freezer is too full
* The freezer door is not closing properly
* The freezer door is being left open for extended periods
* There is a problem with the defrost cycle
If you are hearing water running all the time, check the ice maker water line and fill valve (if you have an ice maker) - there could be a leak or other malfunction.
Apr 15, 2009 | Whirlpool ED5VHGXM Side by Side...
Water leaking from under fridge
Check to see if you have a crack in the water line running to the ice maker. The plastic line is prone to crack. Easy way to see if water is from ice maker is to shut off water to it (usually under sink).
Dec 15, 2008 | Refrigerators
Leaking inside of fridge
i guess u will benifit from this link
plz rate this post
click here
Sep 02, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Candy CPCA240FFK Bottom Freezer Refrigerator Logo
275 people viewed this question
Top Candy Refrigerators Experts
John Tripp
John Tripp
gbob59
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
