Question about RIM BlackBerry Pearl Smartphone
The wireless connection problems for blackberry pearl
Hey, My wireless connection keeps automatically turning itself off after just a few seconds. I go back to the manage connection menu, and check the box that says Mobile network. the little button then turns green indicating i am connected. i exit out of there and attempt to make a call or check an email and the signal then disappears. i go back to the connection menu and it says that the wireless connection is turned off even though i just turned it on. this has become very frustrating. i have never had this problem before and can't understand what precipitated it. Any ideas on what to do? thanks so much
I had the exact same issue with my Pearl. Tried removing the battery, re-activating the phone, etc., with no luck, Finally called Verizon and they sent me a new BB. Now I'm just struggling to get my PC to recognize the new BB!
Posted on Aug 21, 2009
  • 407 Answers
I can't think what may have cause it. I would suggest resetting the phone by turning the handset off removing the battery. Leave for 1 minute and re-insert and turn device on.
Go to networks and allow the device to search networks automatically and turn data service on.
Let me know how you get on.
Posted on Jun 03, 2009
2 Suggested Answers
SOURCE:
mjamesl1220
  • 6 Answers
SOURCE: antenna automatic shut off problems for blackberry pearl
I had this problem a few times, but only when I let the battery drop so low that the connection turned itself off to save what little life the battery had. Once that happens I just had to wait for the battery to charge back up so the connection could reestablish itself. If this is the case, just plug it in and give it time.
Posted on Jun 13, 2009
Blackberry pearl enter (push) function on the
You have to remove the battery when mobile is turned ON and wait for few seconds re insert the battery then check
If problem still exsists connect your blackberry to computer check wheather its recognising the device If "yes" please visit the nearest service centre.
If "yes" you need to take a back up of your hands set and re-install the operating system of your Blackberry. Or else
Nov 24, 2009 | RIM BlackBerry Pearl 8100
Blackberry pearl battery icon with red line ?
First charge your mobile for atleast 1 hour,and switch it ON you to remove the battery when mobile is turned ON and wait for few seconds re insert the battery then check
If problem still exsists you need to take a back up of your hands set and re-install the operating system of your Blackberry. To perform a clean installation of the BlackBerry Device Software using Blackberry Desktop Manager 4.5 to 5.0, perform the following steps:- 1) Open BlackBerry Desktop Manager. 2) Click Help. 3) Select About Desktop Manager. 4) Click the Device Software tab. 5) Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider.
Thank you
Nov 19, 2009 | RIM BlackBerry Pearl 8100
I cant manually activate my blackberry pearl I went to options, mobile network but all it says is roaming.
See if this works....
-Press menu key
-Click OPTIONS
-Select Mobile Network
-Click on "START PROVISIONING"
It should give you a message saying: PROVISIONING COMPLETED SUCCESFULLY.
You wont need a MSL code if you do it this way.
Nov 13, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
The radio on my blackberry pearl will not stay connected
Try this:
Options> Mobile Network> now press the BB menu key> Diagnostics> Now press the BB menu key again Run
Sep 04, 2009 | RIM BlackBerry Pearl 8100
My 8120 pearl, keeps freezing, so far I've exchanged it several times, and it seems like they all have the same problem. When I start playing brick breaker, after a few games (week, or 2) the game gets...
please try doing the following, turn off the sounds, turn off the wireless transceiver while playing, ensure no other applications are running in the background while playing, perform a hard reset on the smart phone.
Aug 09, 2009 | RIM BlackBerry Pearl 8120 Cellular Phone
Radio keeps shutting off
When there is no signal around ur blackberry will shut off the radio instead of constantly searching for one which really kills battery power just make sure you arent in a real signal dead area and you should be fine to turn it back on just go to manage connections and click it back on,if this is not the problem then there might be some problem with ur phone.
Jul 12, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Blackberry pearl 8100 wireless internet support
I'm not sure that the Blackberry Pearl has Wifi... if it does go to manage connections --> enable Wifi... or you can go to Setup... and set up Wifi
Jun 03, 2009 | RIM BlackBerry Pearl 8100
Antenna automatic shut off problems for blackberry pearl
May 26, 2009 | RIM BlackBerry Pearl Smartphone
The 8100 does not have wifi, but the 8130 does.
Mar 15, 2009 | RIM BlackBerry Pearl 8100
Blackberry Pearl keeps turning mobile connection off.
There might be some issue with the BlackBerry Device Software associated with the BlackBerry smartphone so Upgrade the BlackBerry smartphone with a newer version of BlackBerry Device Software and make sure that you have taken a backup before upgrading.
Feb 27, 2009 | RIM BlackBerry Pearl Smartphone
RIM BlackBerry Pearl Smartphone Logo
985 people viewed this question
Top RIM Computers & Internet Experts
Otman Lahlou
Otman Lahlou
Ekse
Vincent G
Vincent G
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
