Washing machine last night my washing machine tripped the electrics and there was a sort of burning smell. now the washing machine wont turn on at all. tried changing the fuse but that hasnt done anything. any ideas what the problem is? thanks :)
  • 1 more comment
  • punkinboots Nov 01, 2007
    if the brushes are replaced will the machine work then? at the moment there is no sign of life!
  • Anonymous Apr 11, 2008
    machine 4 years old no power when loaded and closed door blew 2 fuses 3rd fuse nothing still.has been previously loud and moving alot 6months ago was told is on its way out.so think it needs replacing as cost to fix it would not be worth it.
  • Anonymous Jan 25, 2009
    Washing machine got slower and slower, then tripped the internal automatic fuse, now it won't reset. Everything is dead, even the fill relays....
    Any help appreciated - worked perfect until this.
Check the brushes in the motor. They've probably worn down and need replacing.
Posted on Oct 06, 2007
Washing machine has smell (burning) and doesnt spin or drain tub.
Sounds like the belt may need to be changed. it eh pulley are spinning but the belt is not, nothing will spin and the friction of the pulley against the belt will cause a burning rubber smell
Nov 27, 2013 | Washing Machines
My washer keep shorting out why is this
It may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell.
If the washing machine is old (15 - 20 years) you could have nuisance tripping on aGFCI outlet, however that doesn't mean you get rid of the protection of the outlet, it means you probably should consider replacing the washing machine for a newer model.
Apr 30, 2011 | Washing Machines
I started my washer last night then went to check on it and it was not on. I tried to turn it on but no power. I checked the breaker and it flipped the bresker so I turned it back on. When I push the power...
If the breaker tripped, something shorted to ground in your control panel. You resetting the breaker and pushing the power button then cause something to burn further. I would suggest turning off the breaker then taking the control panel off to see where the "burning smell and small amount of smoke" came from. Look to see if a wire was rubbing against metal somewhere.
Jul 31, 2017 | LG WM0642H Front Load
Burning smell
There's a number of reasons to smell burning after a washing machine cycle. It's a 220V appliance, so if it short's out it will cause problems. It's more likely the motor being overloaded making it hot and causing the electrical burning smell, or a short that's overheating something electrical. Check to see if the belt that spins the whole barrel is melted or worn anywhere. Inspect the wiring that's attached to the system that engages spin, which is different from agitation by the big tower.
If these both check out, an trip to the Maytag Man might have to fix overloading motors or relays, or switches, if anything turns up in your search for the source of the electrical smoke. Ozone is what you are smelling, FYI.
May 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
Blows electrical curuit
It has a serious electrical short, probably in the motor. It needs a service call, unless you're up to doing it yourself. Sounds like it could be very involved.
May 11, 2009 | Washing Machines
Trips out the mains fuse.
must be an earth fault within the machine. suspect a burned out wire or switch. possibly carbon dust within the motor. take the top off the machine & have a look at the wireing loom.
SWITCH THE POWER OFF FIRST
Oct 21, 2007 | AEG Lavamat 72640 Front Load Washer
Washing Machines Logo
367 people viewed this question
Top Washing Machines Experts
