FixYa.com
Tags:
Hard Drives
Generic problem for all Hard Drives
System not detecting hard disk (by 6 users)
posted by arun1234 on Oct 06, 2007
i have 20GB samsung hard disk.i used to transfer large data through inserting my hard disk into friend's PC.once when i inserted it his PC was not able to detect both hard disks i.e.his & mine both hard disks.when i removed my hard disk ,his pc was detecting his hard disk as before and was working fine .so i dont know wht happened to my hard disk and is it now reparable or not.wht shud i do??
please tell me.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by Boyet23, posted on Jun 06, 2008
I have SimpleTech 120GB External Hard Drive but my PC with Windows XP SP2 does not detect the hardware however it can be detected by any laptop computer. What is the problem of this product? It seems that it is not compatible with Desk Top PCs. Or it depends on the Windows package. I installed already the driver but it is not compatible with service pack 2.
Boyet23
Comment by Fleece, posted on Jan 07, 2008
I have the same issue - it says I need to install drivers but the drivers are on the ext hard drive so are unaccessable. Any ideas as the WD website only allows you to download the drivers if you bought from a specific place... which I didn't.
Comment by Guest, posted on Dec 07, 2007
the hard drive aint their.one min its fine the other the thing is gone..the usb say its unknowed and need to reinstal its drives but dont remeber instaling any drivers to the hd
Comment by Guest, posted on Nov 28, 2007
same
Comment by Guest, posted on Nov 12, 2007
the same thing happened to me i plugged my friends hard drive in ..
and now my computer cant find mybook ..
Solution #1
posted on Dec 17, 2007
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I have assembled a new system with Intel Classic Series DG33BU mother Board and a SATA Maxtor 160GB hard Drive.
When booting the computer for the first time I receive an error message. Media Test Failure-Check Cable. The settings recognise the hard drive but itfailes to boot so I can load MB Drivers. Is the Hard Drive damaged and How? It is new.
Sata connections. What can I do?
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Oct 06, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Check the position of the master/slave jumper on the drive.
This Problem Also Relates To: Buffalo Technology (HD-HB250U2) 250 GB Hard Drive Buffalo Technology DriveStation HD-HC500U2 500 GB USB 2.0 Hard Drive Compaq (349239B21) 250 GB Hard Drive Compaq Armada E500 (230659-001) 30 GB Hard Drive Dell (0K724) for Inspiron 8100 40 GB Hard Drive LaCie d2 Extreme (300793U) 500 GB Hard Drive LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
Can you Help with these Hard Drives problems?
LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Will not turn on
My power cord is plugged in,... Answer This...
Kingston (DTIU3/2GB) 2 GB USB Hard Drive
kingston micro sd with adapter
how do i put music into the... Answer This...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB...
Seagate FreeAgent Pro -...
Seagate FreeAgent Pro -... Answer This...
Seagate FreeAgent Go 80 GB USB 2.0 Hard...
usb hard disk no detected
my usb hdd 80GB segate not... Answer This...
LaCie 80GB Mobile Disk USB 2.0 80 GB Hard...
Disconnecting The Mobile Hard...
I just installed a LaCie mobile... Answer This...
Repair Service
Find Hard Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
