Check the easy stuff first, fill hoses tight?- drain hose cracked? Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make.
Seek advice to max small kitchen in Massachusett.
Wondering if anyone has good result installing...
(More)
Wondering if anyone has good result installing washer machine in uninsulated garage.
Would it workable/risky for pipes to survive our cold new england winters?
If so...is is cost effective? Thanks
Kenmore Calypso TL washer - Not sure what CA code is..cannot find paperwork. Seems to shut down in...
(More)
Kenmore Calypso TL washer - Not sure what CA code is..cannot find paperwork. Seems to shut down in the spin cycle.
Our tenants put detergent in a Kirkland (Whirlpool) washer's liquid bleach dispenser, clogging it. ...
(More)
Our tenants put detergent in a Kirkland (Whirlpool) washer's liquid bleach dispenser, clogging it. When I tried to clear it, I may have disconnected a drain hose (or punched a hole in it), because now if liquid is put in the dispenser it leaks out on the floor. I cannot determine how to take the top off the washer to get in there and see what the problem is. Got the washer used, so no manual came with it. Not sure about the model number because it looks like someone removed the label. Where is the model usually put on these washers? Thanks!
In a 15 minute wash cycle the aggitator works fine for the first 12 minutes, but the last 3 minutes...
(More)
In a 15 minute wash cycle the aggitator works fine for the first 12 minutes, but the last 3 minutes when the aggitator normally works slower and more gentle, it just clicks for about 15 seconds then stops working until it drains. Rinse aggitation works just fine.
