Question about Logitech WingMan Light Joystick
Wingman light app. yrs old
I realize its extremely old but i need to find a driver that will run this wingman for my 4 yr old son? Once he gets good than i will upgrade joystick. Any suggestions? I have been on logitechs web site but cant find anything regarding drivers etc .More a sellin website thanks lindanewfy
Go to control panel double click game controllers Click add from the drop down list click 2 axis 2 button Joystick click ok and wait for it to show in the installed game controllers window highlight the entry and click on properties in the window that pops up click on the settings tab and then calibrate the joystick with the calibrate tab when you have done this your joystick will be working ok.
Posted on Mar 07, 2009
6ya staff
SOURCE:
When I plug in my Wingman (win 7-64) and I get the B.S.o.D. and windows has to reboot. any ideas? Im sure my driver is compatible for the system
I have Win7-64, and able to run Wingman. If you have the CD, it is okay, you can install both the joystick and USB drive, but the better option is that you go to the Logitech site, and download the latest drivers for the Wingman. Wingman is the older version of 3D, but the drivers of Logitech extreme, 3D are workable with the old Joystick Wingman., and they should work well on the Window 7 , 64 version
May 03, 2014 | Logitech Extreme 3D Pro Joystick
Need instructions on where or how to go about finding a driver or installer
For your Extreme™ Digital 3D, pls click here. You would be asked for your PC's Operating System (Vista or XP or others), thereafter which file you need (Logitech Gaming software or the Wingman Clear Calibration Utility) and finally whether for 32 bit or 64 bit. Pls follow onscreen instructions.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 06, 2008 | Logitech WingMan Extreme Digital 3D...
Driver logitech wingman attack 2
If the driver doesn't remedy your issue try using the compatability run as in the properties tab. Run in Win-XP in any format you like.
Apr 06, 2014 | Logitech WingMan Extreme Digital 3D...
I need to get a usb adapter for my wingman extreme joystick, but where? IF i can get one will i need a driver to make it work?
No usually you do not need a driver to make it work.The default usb drivers will work.
Logitech does have a exe program for this model joystick also.Which has some nice features.
Nov 01, 2011 | Logitech WingMan Extreme Digital 3D...
How do i set up WingMan Extreme
Hi ! I suggest you to install the software including drivers + profiler here: http://www.logitech.com/en-us/486/3361?WT.z_sp=Image
Then you can download pre-defined profile for your game here: http://www.wingmanteam.com/profiles/profiles_users.htm
Thanks and have a nice day ! J -
Apr 04, 2010 | Logitech Wingman Extreme 3D Pro Twist...
Where can i get free drivers my wingman 3d extreme
Here: http://www.bioticaindia.com/wingman-extreme-digital-3d.html
Although a lot of people seem to have problems with it.
Feb 21, 2010 | Logitech WingMan Extreme Digital 3D...
I can't uninstall Wingman 4.10
Try a Windows system restore to the date before you installed the Wingman 4.10.
It may ask to install the Wingman 4.10 again, but use the program uninstall. If you have to do the windows uninstall again, then what you can do is look into the startup by typing msconfig.
Disable the startup program that you uninstalled.
Aug 20, 2009 | Logitech WingMan Extreme Digital 3D...
Wingman extreme will not work with my vista.
Changing the game to work in compatibility mode for windows xp may solve your problem. right click the game >properties >compatibility and set to windows xp. Good luck!
May 27, 2009 | Logitech WingMan Extreme Digital 3D...
I'm trying to use the cable from my Saitek P750 on my Logitech wingman extreme because the P750 has a USB and a 15 pin the wingman only has a 15 pin. My notebook doesnt have the 15 pin but has 3 USB ports....
Buy a USB to gameport adapter from Radioshack ($1.85!!!! cos it's sooo old) set the switch on the adapter to joystick B (with "hat" switch) and then you can hook it up.....drivers are another issue...I'm still searching..:-)
Apr 11, 2009 | Logitech WingMan Extreme Digital 3D...
Wingman extreme digital 3D Logitech not working on XP
Well you can try download lgs501.exe and run it. This scans on Logitech drivers on your system and can even update them.
( Not checked though, cause I am running on Vista )
Jan 09, 2009 | Logitech WingMan Extreme Digital 3D...
Logitech WingMan Light Joystick Logo
207 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Ekse
Alun Cox
Pierre Laplante
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
