Question about Wharfedale Modus One-Six Speaker
Manual i would like to know if my amp is going to be ok to run these units my amp is a marantz PM 230Ser No 38A040070
Marantz PM-66 SE: Power light comes on, but the amp does not work
try taking a flashlight and look through cover into unit for a blown fuse or take cover off (which is better) if taking cover off unplug unit. If a fuse is blown remove it and take to a store like Radio Shack for proper fuse watt and amp..if fuses are ok i would get it fixed...sounds like a minor problem since main power is there. GL
Aug 08, 2014 | Marantz Audio Players & Recorders
Marantz problems
The speakers are 8ohms. Always try using speakers 6 or 4ohms. For B&W 683 on PM 6004 is too low. You should go for PM 7000 or 8000 series to catchup with 683. Also when you increase the volume please decrease the bass as well.
You need 8ohm 55w to 90w or 4ohm 80w to 110w speakers.
Jul 20, 2014 | Marantz PM6004 Integrated Amplifier
Hello i have a marantz pm-47 amp that keeps blowing every time i plug in the power feed to the amp board i have changed the 2 caps on the board but still have the same problem i checked voltage for...
Hi mas_66,
Make sure that the fuse is the same rating with the old one.
If still symptom persist, I've suspected that your output IC is shorted.
You may hang this IC, then power up the unit.
Observe what will happen, if this cure the symptom then this is a clear indication that this IC is shorted and made the fuse blown while it is in the circuit board.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 08, 2011 | Marantz PM-68 Amplifier
Can i connet my marantz ki17 amp to a power amp
Hi, i don't really understand why you want to connect an amplifier to an amplifer.
Might be that you want to get a louder volume or ?don't know.
I don't think there is any need for you too connect marantz ki17 amp to a power am. Both do the same work, but might have different watts.
So you will need to check what you want to connect with the amplifier first and check the watts that can carry it without interference from the amplifier.
I guess that would do the magic.
Have a nice day.
Feb 18, 2011 | Marantz PM-15S1 2-Channel Amplifier
Hi I have two marantz amps witch cut in and out when run from
In stereo terms your system is "clipping" which means you are pulling more amps than the system can handle. If it happens only when you use the mixer, I'm thinking the mixer cant handle the power. Check the specs, It should show maximum amp input.
Jun 04, 2010 | Audio Players & Recorders
I have a Marantz PM-66SE Ki amp which appears to have a problem with one of the channels which is only outputing about 10% of the volume of the other channel. Have tried swapping speakers and cables around...
I have exactly this same problem with my Marantz PM60100SE - one of the channels seems to have lost power and is much much quieter than the other one.
Did you find a solution to this? Anyone have any ideas?
May 20, 2010 | Audio Players & Recorders
Heat in operation of marantz pm 74d
Sounds like your left channel output transistors are getting weak.
Jan 17, 2009 | Marantz PM-68 Amplifier
Can I remotely control speaker outputs on the Marantz PM 8003?
HI...
You need an 8 ohm stereo "L-pad"
Try partsexpress.com
or
mcmelectronics.com
Dec 21, 2008 | Marantz Audio Players & Recorders
Marantz PM 4000 has cut out
May be the problem solved here :
http://www.audiotoolers.com/ubbt/ubbthreads.php/ubb/showflat/Number/5316/page/1#Post5316
Nov 21, 2008 | Marantz Audio Players & Recorders
Marantz PM-48 connecting to TV
look on the back of the TV and there should be L/R audio outputs (white & red), connect this to a spare input of your amp via a connecting lead eg. AUX or any other input except PHONO.
hope this helps.
Oct 19, 2008 | Marantz PM-68 Amplifier
Wharfedale Modus One-Six Speaker Logo
60 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
Joaquim Martins
 Grubhead
Grubhead
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
