Question about Nintendo DS Lite Console
Bottom Screen doesn't work but lights up
My son dropped his DS lite on the floor and now the top screen works fine - the bottom screen is white but has no graphics.
I had the same issue... You will need to replace the bottome screen. You can get it on ebay cheep and fix it yourself.
Posted on Oct 08, 2007
Cable problem most likely usually cheaper to replace.
Posted on Oct 06, 2007
SOURCE:
White Bottom Screen
The bottom screen is fiddly to replace, but easier than the top one lol. Get a cheap screen off Ebay/DealExtreme and DIY - DIY guides are on YouTube. Specialist tool needed is a tri-wing driver.
May 25, 2010 | Nintendo DS Lite Console
Pastel colors in upper screen
Take it to get checked and lower the back light.
Aug 06, 2009 | Nintendo DS Lite Console
Bottom screen black
Your bottom lcd is busted. It'll have to be replaced.
Look online for Nintendo DS bottom lcd replacements.. Fairly cheap
May 17, 2009 | Nintendo DS Lite
Turns on and lights up but no images on top screen
The DS top screen has two components, which are the LCD display, and the backlight. If the LCD display has gone bad but the backlight still works and the connecter is seated properly, the DS will still power on and the lower screen will be normal, and the top screen will light, but it won’t display anything.
You didn’t mention if your DS is the original DS or the DS Lite. Replacement top screens for the DS Lite are cheap on eBay, but installing the screen is a bit complex. The screen for the original DS is a different part and they are more expensive and hard to find.
I’ve never worked on an original DS, so I can only tell you about installing the top screen on a DS Lite.
First, the DS Lite has to be just about completely disassembled. You have to completely remove the top and bottom cases, pull out the microphone and wi-fi cables, and release the connecter for the top screen, which is located on the main board in the lower case. You’ll need the tri-wing screwdriver. You can leave the bottom screen/touch screen assembly attached to the main board, but be careful not to pull or tear the flex cables. Check YouTube for videos on disassembling the DS Lite.
Here’s the deal breaker for most people: The speakers are soldered to the flex cable of the top screen. I’ve never seen a replacement sold with speakers. You’ll have to unsolder your speaker wires from the old screen cable and reconnect them to the new one. If you can’t solder, you could take the screens to a local tv/electronics repair shop and pay to have it done. I got this information for you from http://wiinewz.com/forums/nds-general-discussion/72805-ds-top-screen-white-blank.html this appears to be a common problem I hope this helps
Dec 01, 2008 | Nintendo DS Lite Console
Nintendo DS lite - dropped
Might be worth taking it into a phone repair shop to see if they can replace the LCD screen. (yes, a phone repair shop - a lot of them do portable console screens too!) If they can't do it, it's probably unfixable realistically.
Mar 27, 2008 | Nintendo DS Lite Console
DS LITE BOTTOM SCREEN IS WHITE WITH BLUE&GRAY LINES
u need a new screen in the bottom, try to get a nintendo brand screen instead of an aftermarket.
Dec 15, 2007 | Nintendo DS Lite Console
Non-working top screen
If you see lines on either screen of your Nintendo DS Lite during game play, then it is likely one or more of the components that create the image on the screen are damaged. This can occur if there has been an impact -- such as being dropped or hit -- to the Nintendo DS Lite's screens. Phone 1-800-255-3700 to discuss available repair options and they will be grateful to assist you at any time of need.Important Note: If you are seeing lines on the screen that slowly fade away after turning off the system, this is normal.
Oct 28, 2007 | Nintendo DS Lite Console
Lights on bottom screen don't light
i dont think it is a problem i think it just does it to save energy
Oct 03, 2007 | Nintendo DS Lite Console
Top Screen of DS has faded to white
if he dropped it then the bottom should not show up as well. the bottom screen you can play the older games plus get instructions for the new games. if they are both out then it is the motherboard. if it is top only, it is the lcd screen and you can get that replaced for about $45. find a place to fix it or send it to nintendo. thanks, connie
Jun 22, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
383 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
