Next time it overheats, check the bottom radiator hose. If the engine is hot and the hose is cold you have a thermostat sticking closed and will need replaced. Has anyone replace the thermostat lately? They can get reversed when installed. Don't laugh it has happened. Another thing most thermostats are made with a weep hole to rid the block of air. If this hole becomes plugged and you have a bad intake or head gasket leaking coolant the level can get below the thermostat it will overheat. Has to be in coolant to work.
Thermostat
SOURCE: 92 toyota celica cranks does'nt start no spark at plugs 124,000 miles
SOunds like the timing belt has broke. To check you can take off distributor cap and turn over engine and see if the rotor turns. If not you have a busted timing belt. Please rate this a fixya if this helps.Thanks!!!
SOURCE: 1995 toyota camry-stalling out when driving
You do not have to replace the fuel pump at a specific mileage.
I hate to speculate without physically inspecting the vehicle, but, my best solution here & now may be the fuel pump. Now, I would not go out & buy one before you had proper diagnosis. Here is one test, but you will need to have to experience the stall again, and then test to see if you have fuel pressure at the injectors. If you have no fuel pressure, replace the pump. Fuel filter issues do not "come & go", they stay, and your car would not run properly. Also, a fuel pump failure will not set a computer code on this particular model vehicle. Hope this helps..
SOURCE: My daughter's 1987 4 runner won't start after driving some.
My 1987 4 runner won't start after driving around. I can charge or jump battery and the 4 runner will start, changed the altanater and battery also going to change starter HELP
SOURCE: car doesn't have any power
This happened to me and yes it was caused by a timing belt i replaced it and guess what? My car took forever to pick up speed but once i hit 30mi than it was fine. So i found that one valve was bended so i had to rebuild the heads now its fine one way to find out if you have a faulty valve is by unpluging one of the spark plugs wires you are probably running on 3 cylinders thats why it has no power until it reaches some speed then its fine but when you stop and try to go again it does the same thing i recomed 4 you to go check the heads i bet thats what is wrong with your car. Youll end up paying arround 500 bucks! ! Parts and labor but its a. 1990 celica worth it? Yes its the best car i have ever owned!! And if it happens again i will fix it i love my celica! !
