Question about iLO (2 GB) MP3 Player
Display flashes on and then Off when turning on
My iLo flashes on and off quickly when I attempt to turn it on. I then install a new battery it will work for about a couple of minutes, shuts down and then begins the flashing. I remove the battery and check it with a voltmeter and the battery is still fully charged.
  • 8,596 Answers
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 05, 2008
SOURCE:
When i turn it on it just shows the ILO symbal and flashes
Hello.
In order to fix Your iLO Mp3 Player please follow these steps:
  1. Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.)
  2. Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible.
    Download the Firmware.
  3. Click Open to initiate the download.
  4. Double click on the ILO or Siren folder icon. There will be 14 icons.
  5. There will be a Setup icon that looks like a box with a blue line on it; please double click on this.
    Then click Run - this will open the Install Wizard.
  6. The Install Wizard has the instructions on the screen as you go through it.
    Once the firmware has installed, please click the Start menu, then Programs.
  7. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware.
Additional Tip: The player itself requires a lot of power while flashing the firmware. We suggest disconnecting all USB devices from the computer except the MP3 player and mouse; you can reconnect your keyboard once the firmware has been flashed.
Good Luck.
Nov 03, 2009 | iLO (2 GB) MP3 Player
Ilo 2 GB Flash mp3 Stuck on ilo screen.
link your USB port between Computer and ILO player.
1.Click on START at lower left corner on you computer. choose "Explore"
2.look for ILO driver on start manu on left hand side. left click one on it. right hand click you will see the drop down options
3. Choose "Format" BESURE that you are going to format ILO NOT your hard drive. it will ask you again that you really want to format it. "yes"
4. copy new mp3 files to ILO. That will be finished. you can start playing it again.
Hope this help.
Pin
Jul 13, 2009 | iLO (2 GB) MP3 Player
Just stopped working
"Firmware Upgrade" (provided by jwmgotee):
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
Download the correct Firmware
Click here (https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip) to download the ILO 116 Firmware
It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start".
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
"Found new Hardware 'SMTP3500".
-Tha Mp3 Doctor
Sep 27, 2008 | iLO (2 GB) MP3 Player
Flashing Intro. but no music
May 25, 2008 | iLO (2 GB) MP3 Player
Won't turn on correctly-flashes on and off
My ilo will not turn on! I've tried changing the battery - but no luck.
Feb 20, 2008 | iLO (2 GB) MP3 Player
Mp3 player
well i guess that the problem can be that the same program from the mp3 was erased, guess u gotta re install the program, i'm kind a looking for it too so let me know [email protected]
Jan 26, 2008 | iLO MP3 Player
Ilo mp3 player model MP-556
connect your mp3 to the computer then right click on the drive click format. after that you mp3 is now good as new.
Jan 18, 2008 | iLO MP3 Player
How do I turn on the ILO MP3/WMA digital Audio Player w/1GB
system Recovery for the ilo mp3 player,
because it has being formated .
Dec 01, 2007 | Audio Players & Recorders
Ilo mp3 player won't turn on
Do you have music on it? Maybe its playing something, and it just turned off the screen.
Aug 25, 2007 | iLO (2 GB) MP3 Player
Downloaded music onto it then it just keeps flahing ilo
OK this is an "Internal" problem and it must be returned to the supplier/manufacturer for repair/replacement. I have seen this countless times B4.
Jul 29, 2007 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
Top iLO Audio Players & Recorders Experts
Ekse
Siul Oyaratgam
Rick
Rick
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
