My Cancel light is on unless I use the pot scrubber cycle. I want to use the normal cycle.
SOURCE: The control panel works intermittently.
HI friend
it may be also timer problem .....did you touched it with wet hand...better to check timer,,,
thank u,,,,,,,,,
SOURCE: Normal cycle never completes. Have to CANCEL to
check the temperature is reached the setting temperature,
or replaced the control board
SOURCE: Pots, pans, dishes not coming clean, white residue left?
Check your heating element..
Dishwasher Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
SOURCE: KUDS01FK diswasher will not start
Hello
first push and hold the cancel for 15 seconds and the if that dont reset the control push these buttons
normal wash ,, hi temp scub
if either of these resets the control the you will have to replace the control panel / thanks
Load the appliance with dirty dishes, placing soiled pots and pans on the lower rack where they will be subjected to the most vigorous cleaning. Glassware and dishwasher-safe plastics should go on the top rack. It is not necessary to rinse dishes before loading them in the Hotpoint appliance, unless the dishes have been sitting for awhile and the food particles have dried.
Fill the detergent compartment with your preferred brand of dishwashing detergent, and add glass rinse solution to the rinse reservoir on the inside of the door if your model is equipped with one, then close the door to lock in place.
Select the cycle you wish to use and press the button. For pots and pans, use the heavy-duty cycle. Normal wash is fine for dishes and utensils.
Save on your energy bill by running the dishwasher only when it is full and by allowing the dishes to air dry instead of using the heat dry function on the appliance.
