Question about Candy 17 in. CS455 Built-in Dishwasher
Candy CDI 1012 Dishwasher
Hi the dishwasher stopped mid cycle. There is now no power. I have changed the fuse and also replaced the plug. I have checked the socket nothing wrong. Any thoughts? vic ps keep getting select product but no choice for my dishwasher so clicked any.
  • 2 more comments
  • dazzasmiff Jan 02, 2008
    Candy CDI 1012 stopping mid cycle, all LED lights are flashing rapidly and water has not drained.
    I've cleared the water manually re-set the program, but it always stops on the drainage stage
  • Lombear Feb 21, 2008
    I have a similar problem with the same model dishwasher. Mine is stopping about 2 - 5 minutes into a wash. I have to reselect the programme and try again. Normally after about 3-4 attempts into continues and finishes the wash asit should do.
    Any ideas, it's about 17 months old.
    Thanks
  • Anonymous Mar 12, 2014
    stops in middle of cycle and we get a pulsing
    noise
  • Anonymous Mar 14, 2014
    Not completing cycle
  • 209 Answers
Providing its not under guarantee remove mains plug and remove door skin from front of door carefully, as it has to go back on, look for any broken wires just above the door hinge, there will be about 10 or 15 wires, its possible that if you have checked what you said have checked properly that one of these wires has got hot and broken (very common fault of all dishwashers aver 3 year old) replace wire with care etc, work safely,
Posted on Oct 07, 2007
Kenmore elite dishwasher stops mid cycle
I assume you mean it stopped in mid cycle and is now dead. If this is the case you will need to turn off the power to the dishwasher and remove the screws holding the front control panel There is a thermal fuse clipped to the front of the control panel Check it using an ohmmeter or continuity tester If it is open you will need to replace it with a kit containing the fuse and wire connectors Do not replace just the thermal fuse the problem will surely return. Also inspect the control board for burned areas.If the control board is burned you should replace the wiring harness with the control assembly
Jan 25, 2014 | Kenmore 24" Built-In Dishwasher with...
Candy cdi 1012/2-80 is leaking at bott of door. Whats up.
my candy dishwasher is leeking from the bottom of door what can i do
Nov 23, 2010 | Candy DFI Plan Built-In Dishwasher
I have a candy cdi 3515 and after about 1/2 an hour into the programme it stops and a continuous alarm bleeping starts.
Is there water in the dishwasher when it stops?
Are you able to check if the water is normal temperature or warm/ hot?
Can you try the dishwasher in a short cycle and see if it completes the cycle?
Oct 11, 2010 | Candy Dishwashers
Candy dishwasher CDl 1012/2-80, program stuck?
Hi Derek if its only been used about as you say ten times it will stil be under gaurantee,just call the supplier and have them solve the problem for you mate it sounds as if the program selector is faulty as it is all eletronic programming and could even be a faulty circuit board.
hope this helps
regards JL
Oct 04, 2009 | Candy Dishwashers
Candy cdi 1012 dishwasher
Did anyone ever manage to work out what the cause of this was? Our dishwasher is exactly the same. We had it fixed once under warranty and it lasted about a year before breaking again. Unfortunately we never asked what work was done during the first repair. Thanks. Stuart
Dec 20, 2008 | Candy DFI Plan Built-In Dishwasher
Dishwasher wont complete program 1 2 or 3
Did you ever resolve this problem with your dishwasher, unfortunately i've exactly the same type of problem!
Thanks Steve
Dec 18, 2008 | Dishwashers
Washer keeps stopping mid cycle
Bad timer motor or mechanism...accordianman
Mar 21, 2008 | Dishwashers
Candy 17 in. CS455 Built-in Dishwasher Logo
1,135 people viewed this question
Top Candy Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
