Home | Frigidaire | FAC107P1A Thru-Wall/Window Air Conditioner | Window unit not coo...
Frigidaire FAC107P1A Thru-Wall/Window Air Conditioner
Problem for Frigidaire FAC107P1A Thru-Wall/Window Air Conditioner
Window unit not cooling properly, minimal cooling
By shfinger on May 03, 2009
the end of the thermostat seems bent or broken inside sleeve, could this be the problem. have not heard compressor cut on all day. first time this season on. At the end of last season didnt seem to be cooling well. live at the coast of NC. model # FAC107P1A bought 2007. Blower fan working fine. remote works. clean filter and clean outside vents
Clarification Request
Posted by joed202902 on May 03, 2009
If the cap tube line for the thermostat is broken and has lost its charge, then the compressor won't run. You could try jumping out the control and see if the compressor will start.
Solution #1
posted on May 03, 2009
Not Rated)
SHINEBONES21
Rank: Master
Rating: 90%, 1 votes
SOUNDS LIKE ITS LOCKED OUT ON LOW LIMIT OVERLOAD CHARGE THE AC SHOULD START UP WHEN COMPRESSOR GETS AMPLE FREON
Was this helpful?
Yes
No
Popular Solutions for Frigidaire FAC107P1A
Questions and Unsolved Problems for Frigidaire FAC107P1A
Do you recommend Frigidaire FAC107P1A Thru-Wall/Window Air Conditioner?
Answer
Answer
my model faa086pta frigidaire air conditioner will not power on. the reset button is working on... (More)
Answer
Hi, my air conditioner, i changed the setting from cool to fan(outside air blowing in)- the unit... (More)
Answer
we bought ours from lowes and it was the display item it came with no instructions, can you tell us... (More)
Answer
My Frigidaire fac107p1a a/c will not power on. I tried resetting the plug but still no power. I... (More)
Answer
where does the white and black wire from the power cord hook to under the panel? I know where the... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Frigidaire FAC107P1A...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
