Question about Konica Minolta DiMAGE Z3 Digital Camera
Z3 starts in selftimer mode.
When camera is switched on,the first shot always goes into selftimer mode.subsequent shots become normal.
SOURCE: Camera shuts off after one shot
Set the camera to clean ccd mode and carefully remove the lens. If you can't see the ccd but only the shutter then the shutter is sticking. I have this problem when not using the camera regularly. My solution to free the shutter was just to set the camera to long exposure and just keep restarting the camera and taking a photo until the shutter moves. This problem happened from the very first time I had the camera run low on batteries at a few months old but at the time I never checked the shutter and the camera just restarted once and it worked.
Posted on Mar 08, 2009
0 characters
1 Points
I have a fine pix digital camra A340 do not have instuction book .Need to know how to set the timer to take pics where you jump in the picture later
Press Menu/OK. Use the zoom rocker to select the icons in the bottom of the monitor. 2nd symbol from the left is the selftimer. Set Selftimer to ON and press the shutter button. It will give a 10 secs. delay. You can cancel the selftimer with the Disp/back button. The selftimer has to be activated for every shot.
Sep 21, 2010 | Digital Cameras
How to use selftimer
In any Still mode, press the down-arrow repeatedly to choose between 10 seconds, 2 seconds, and 2 shot. In the 2-shot mode, the camera takes one picture after 10 seconds and another 8 seconds later.
Jun 20, 2010 | Kodak EASYSHARE M1063 Digital Camera
How do i do black and white photographs
This is the manual for your camera.
Search the pdf file for BLACK AND WHITE
(copy and paste that to your browser....where the WWW is.)
says to use the FinePix COLOR. settings : STD / (C) / (B) This setting can be used with any of the modes. Specifies required color tone. This mode is effective for taking more vivid shots or black and white shots.
Hope this Helped x404x
Mar 01, 2010 | Fuji FinePix Z3 Digital Camera
Hi, im getting an overexposed effect on my still shots.. almost a whiteout and then i may get a normal exposed image with a subsequent shot all my settings are on auto.. my video recordings are...
best place to start with would be t reset the settings to factory defaults
this will set any high exposure, shutter, aparture settings that have stayed back to normal
if there is any clarification further u need then u may add a comment to this thread or may mail me
happy clicking
pls rate if this was any help
Jul 14, 2009 | HP Photosmart M525 Digital Camera
Sony DSC H-5 Camera slow response time
you might have switched the shooting process to timer mode. please refer the instruction manual to change it back to normal mode.normally there will be button near the lcd screen with the symbol of a timer deviice. if you click it once it sets the delay of shot to 2 sec and for the second time to 10 secs.and for the third time, it goes back to normal mode. thanks for using fixya. please dont forget to rate my solution!!!
May 29, 2009 | Digital Cameras
I would like to know how use use the selftimer on the olympus 310
Page 72 and 73 of your advanced manual explains how to use this feature.
Basically you can have the camera selected to any mode on the mode dial - press Ok - right arrow to Mode Menu - highlight camera tab and left arrow over and then down arrow to the symbol that looks like a clock - this is the self timer option. right arrow over and make sure you select it to on - and then press ok.
Press the shutter button fully to
take the picture.
• Pressing the shutter button halfway locks
the focus and exposure.
• The self-timer lamp lights for
approximately 10 seconds, then starts
blinking. After blinking for approximately 2
seconds, the picture is taken.
• The self-timer mode is automatically canceled after one shot.
May 08, 2009 | Olympus SP-310 Digital Camera
Have to press button down twice to take shot
This is your first SLR?
The normal procedure is to press the button halfway to get the focus. This is indicated by one or more red LEDs lighting in the viewfinder and a confirmation beep. Once you have this, you press the button fully to take the shot.
As the camera will not take a photo when not in focus, then pressing the button once and letting go will focus it, and pressing it again will take the shot.
Get used to pressing it halfway before taking your shots and it will soon become second nature to you.
Feb 11, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Cannon sd 600,self timer How to use the selftimer
1. Make sure the camera is in shooting mode (silhouette of camera)
2. Press Func/Set button
3. Scroll down to Drive Mode icon (usually single square)
4. Use left/right arrow to select 2-sec or 10-sec delay (clock with 2 or 10 next to it)
5. Press Func/Set button
Now whenever you press the shutter button, the camera will delay 2 or 10 seconds before snapping the picture. Remember to set back to single shot (single square) or continuous shooting (three overlaid squares) mode when done.
May 28, 2008 | Canon PowerShot A520 Digital Camera
Dimage Z3 self-timer
It is in the Drive mode, the options are single shot, continuous, bracket, and self timer. It is not very clear in the manual but it is on the 1st menu page, page 46. Navigate using the arrow button. The default is single shot. When you set the camera to self timer, after taking the shot, it will return to the previous mode, ie. single shot or continuous. If you always use the self timer, you can reprogram the flash mode button to set the drive mode without going to the menu, page 65 of the manual. If you do not have a manual, you can download here :
Apr 23, 2007 | Konica Minolta DiMAGE Z3 Digital Camera
What kind of focus settings does the DiMAGE Z3 have during movie recording?
The following three settings are selectable during the movie recording: Continuous AF: The single-shot AF is operated in advance of recording, and AF is always operated during recording. Single AF: The single-shot AF is operated in advance of recording, and the focus position is fixed during recording.*This mode is useful for shooting a low contrast and hard-to-be-focused subject, such as fireworks. Manual: The focus point is to be set manually in advance of recording, and its position is fixed during recording.*Manual focus is useful when it is difficult to focus automatically.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Konica Minolta DiMAGE Z3 Digital Camera Logo
13 people viewed this question
Top Konica Minolta Digital Cameras Experts
Level 1 Expert
Are you a Konica Minolta Digital Camera Expert? Answer questions, earn points and help others
