Question about Canon NP 6551 Black and White Copier
I have a Canon NP 6551 copy machine and we have a Error E001, how I can fix this error?
WEe vstart the copy machine, but the machine doesn't work in the screen says E001, Switch the power off and on again, we did several tiems but machine still not work, What can I do to fix the problem
SOURCE:
  • 100 Answers
SOURCE: Solve System Error E001
it needs a new fixing unit. Youll need to call a tech for this, the finixing unit cost the dealer 180 bucks and the make up is around 50% so its not a cheap unit. There also adjustments that need to be made in service mode so you really need a Canon tech that knows how to get into the service mode and make those adjustments for the new part.
Posted on Jan 16, 2009
  • 118 Answers
SOURCE: Canon NP 6551 When putting paper in the
a sensor in the adfeeder could be contaminated by dust if you have the blower try to blow the whole feeder unit check also if there a two tongue like black plastic that is coming out on top of the originals when pressing the start button.if this thing will not come out the machine will tell you to put the originl again
Posted on Jul 05, 2009
SOURCE: NP 6551 Black and White Copier: how do you fix the sorter on a canon 6551 copier?...
mi canon np 6551 me marca error E004
Posted on Aug 22, 2010
  • 122 Answers
SOURCE: I have a copy machine the model is canon np 6551
it is code for cleaning web. the fuser cleaning web may have tqken up completely if so, replace it. else check sensors which detect taken up cleaning web.
Posted on Jan 29, 2011
bilalkhtak
SOURCE: Canon IR600-550-60. Error code E001.
550 just gave an error code E060, what do I do?
Posted on Nov 30, 2012
6551 E01
try unplugging it for a few minutes first and see if that helps at all, and let me know and I will further assist you with this problem
Apr 29, 2008 | Canon NP 6650II Copier
What is a fixing web on a cannon 6551 Black and white copier
The Fixing Web is a roll of oil impregnated fabic that sits on top of the upper fixing roller. Its purpose is clean the fixing rollers between copies. It lasts somewhere around 250,000 copies. Needs to replaced by a service tech and have the counter reset. If the Web runs out you get a E-005 error code.
When you open the front door and release handle and pull out the Paper Transport fixing assembly. The Web is under the yellow cover on the left side.
Mar 19, 2010 | Canon NP 6551 Black and White Copier
Error code E20 in Canon NP 6241 copier
Check this code - does it read E020 ? if so this is usually a result of toner starvation possibly caused by a faulty toner sensor in dev or hopper unit.I have also found the toner hopper supply motor can fail with the same result. In either case it is an engineers job to rectify. Good luck !
May 19, 2009 | Canon NP 6551 Black and White Copier
Error message - re insert unit 1
GO ON LINE AND TYPE THE FOLLOWING:
CANON NP 6551 B/W RE INSERT UNIT 1
ENTER
WHAT IS CANON NP6551 B/W UNIT 1
ENTER
CANON NP 6551 B/W SERVICE MANUAL
ENTER
ROD
Feb 17, 2009 | Canon NP 6551 Black and White Copier
Canon Np 6551 e502
that error is a communication error between the copier and the sorter unplug the sorter then turn the copier on should go away. probably loose connector or bad sorter board
Dec 19, 2008 | Canon NP 6551 Black and White Copier
Canon NP 6025 Sorter error
if you tell us what the problem or error code is ??????????????????????
Sep 10, 2008 | Canon NP 6551 Black and White Copier
Canon 6025
"E001" Abnormal fuser temp. (thermistor, dc controller, ac driver)
Nov 17, 2007 | Canon NP 6551 Black and White Copier
Canon NP 6551 Black and White Copier Logo
22 people viewed this question
Clive
Clive
old marine
old marine
Ekse
