Question about Microsoft Office Standard for PC
Normal distribution curve
How do I chart two normal distribution curves in the one graph
  • 3,037 Answers
Re: Normal distribution curve
If you right click on the graph and click on edit data or source data, you should be able to graph another set of data, depending on if you have office or vista, it may be under something different but will be very similar
Posted on Mar 18, 2008
0 characters
3 Points
What is excel
Microsoft Excel is a commercial spreadsheet application . It features calculation, graphing tools, pivot tables, and a macro programming language called Visual Basic for Applications.
Microsoft Excel has the basic features of all spreadsheets, using a grid of cells arranged in numbered rows and letter-named columns to organize data manipulations like arithmetic operations. It has a battery of supplied functions to answer statistical, engineering and financial needs. In addition, it can display data as line graphs, histograms and charts, and with a very limited three-dimensional graphical display.
Jun 04, 2011 | Microsoft Excel for PC
I need to curb the text kind of like word art in corel x4 can you help me to do it or how to do it
To create curved text you need to use the text tool and fit to path. When you create a shape, line or curve and then select the text tool you can make the text take the same path as the object you created by just hovering it over the objects outline, you should see the courser change.
1- Draw the a curve
2- Select the text tool and hover it over the curve that you created and then when the course changes click on the line activating the text tool
3- Type the text
4- Select the curve and change the outlone color to transparent
Jun 10, 2009 | CorelDRAW Graphics Suite X4 for PC...
Does the Graph/Chart option exist for Mac Excel?
Yes, it does.
Choose the data in which you want to graph by highlighting said data, including and row/column headings. Then click the icon, which looks like a graph, in the top toolbar which will open up the Chart and Graph Wizard. Then follow the steps and guidelines to create your chart or graph.
Hope this helps. Have a great evening!
Feb 17, 2009 | Microsoft EXCEL 2004 for Mac
Sigmaplot graphing problem!
its a virus my dear,, or its a corrupted Windows XP?? can i ask u?? you are installing an original windows XP? or it is an imitation? in order for me to know the system file?
Nov 20, 2008 | Systat SigmaPlot 9.0 (000053608314) for PC
What is data series in microsoft excel
The data series the the string of data you would like to have included in a formula or charted on a graph. For example, if you have data in cells A1, A2, and A3 and would like this data to be included in your formula or chart, it would be designated as A1:A3, translated as A1 through A3. This can most easily be accomplished by highlighting the data when the software is asking for the data series.
Nov 18, 2008 | Microsoft Business & Productivity Software
How do I run a regression analysis in Excel
You probably want to use the LINEST function for straight lines or LOGEST for exponential curves.
In Excel 2007, there are a few tricks. One is to select a range of cells and enter your formula there. If you do not select a range of cells all the variables (coefficentis, R2, errors, etc) will not be dislayed.
The other tricks is one must hit Ctrl+Shift+Enter to display the results. is a link from Microsoft with a detailed explaination. Happy OLS regressing!
May 13, 2008 | Microsoft Excel for PC
No I believe there is no hot key for this. One can manually click and drag the chart or use the resize function.
On the Format tab, in the Size group, enter width and height.
Alternatively, you place the chart in power point and use the presnetation function to see it full size.
Feb 13, 2008 | Microsoft Office Professional 2007 Full...
Graph plotting
Dear rachana, In MS word 2007 you can go to Insert then there are multiple graph patterns given in it, like column, pie and scatter chart. Just put your values in it and it click ok, you will get the chart on worksheet. Its that simple.
Please press fixya if that was helpful.
Nov 29, 2007 | Business & Productivity Software
i have 2 columns in an excel. One column has data like a,b,c,d,e,f,g,h,i,j,k,l and the other column has values like 0,1,2,3,0,0,0,0,0,5,8,0 respectively. Now i have to generate a graph(pie chart and column chart). But the graphs should not have data and values that have 0 values. i.e, the graph should contain these data and values respectively. data: b,c,d,j,k values: 1,2,3,5,8.
Sep 23, 2007 | Microsoft Office Standard for PC
Excel 2007
Darcy,select the data and then open the graph option then put the values
Sep 20, 2007 | Microsoft Office Standard for PC
Microsoft Office Standard for PC Logo
291 people viewed this question
Top Microsoft Business & Productivity Software Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Microsoft Business and Productivity Software Expert? Answer questions, earn points and help others
