Question about Asko T780 Dryer
The display and programm buttons are dead
Hi! I have a problem with my machine. My powerbutton led is on but not the machine, the display and programm buttons are dead aswell. I have checked the safty fuse on the back of the machine and it´s not that. Can someone please help me with this?
  • Anonymous Nov 18, 2008
    I Had the same problem and I found the answer on this post's solution...just had to press our reset button on the back of the dryer.
    Thanks!
  • 175 Answers
Sounds like you need to push the reset button on the lower left rear of the machine, unless thats the button you are already talking about. There are also some fuses on the back of this dryer that tend to fail. You have to call an ASKO servicer to install a factory bypass kit to repair this problem. Replacing the fuses will not solve the problem, as its the fuse sockets that melt and fail. Hope this is helpful!
Posted on Nov 06, 2007
How do i connect the front panel (Powerbutton etc.) with my acer m7721 motherboard?
If you have knowledge of computer hardware and also have a tool for open the computer cabinet, look at the 9 pin on motherboard one is shot out of ten pin, in the pin panel there is market some word to connect the panel Like Pw bt -Power button, Rst-Reset, Pwr-Led-Display Led, HDD-Hard disk Led, and SPK-Speaker Button. Inser all cable acordingly which is allready marking with coat sign
Sep 23, 2014 | Acer Aspire 7720 Notebook
Aeg 72630 update
Press first left up button and first left down button simultaneously
( during the execution of the washing programme ) for at least 2 seconds: the LED switch off and then display the sequence of flashes indicating the alarm.
The alarm sequence is displayed for the time in which the buttons are hold down.
When you read the alarm code,we will be able assume what may be faulty.
Dado
Aug 31, 2014 | AEG Washing Machines
'washing machine miele w1714 lock on Message demo programme how i do unlock?
Demonstration Mode (Dealer Displays)
Initial requirements
- Switch off the machine.
- Close the door.
Note
Once you begin the access procedure, it must be completed within
10 seconds.
Accessing
1. Press and hold the Start Button while switching the unit on with
the On/Off Button.
2. As soon as the Start LED lights up, release the Start Button.
3. Immediately press and hold the Start Button, until the Start
LED turns off.
Deactivation
Repeat the accessing procedure.
Note
The Demonstration Mode is NOT deactivated when the power is
shut off with the On/Off Button, or by unplugging the appliance.
Nov 04, 2012 | Washing Machines
Switch on it shows "test" and cannot programme
It depends on what date the machine was manufactured. The date should be on the plate which is probably in an awkward position on the back ;-0(
Date code 39 March 2005
Press start/cancel until ALL LEDS are lit
Press both start/cancel AND on/off together until 'dOFF' is displayed
Date code 39 March 2005 to date code 42 June 2005
Press the cancel button and the machine should return to normal
Date code 43 July 2005 onwards
Press both start/cancel AND on/off TOGETHER with top left option button until 'dOFF' is displayed.
John C
Mar 22, 2011 | Hotpoint Aquarius WD640 Front Load...
I have just changed the brown control board and now i have a fault code 9
Hi and welcome to FixYa. I am Kelly.
You did not provide a make and model number so here is my best model to problem guess....
Your new control board is missing the size information.
AQUASMART-SIZE-SETTING. Size information must be programmed when a Motor Control Module or Display Module has been replaced. If the size is not set, the display will show fault code 9, or the water levels and wash actions will be incorrect. If the machine displays fault code 9, the machine must be switched off at the wall and then back on again before it can be sized.
Setting the size:
Unplug at the wall and then re-plug it in.
Press and hold Temp Up, then press Power. Wait for the 4 beeps, then set your machine size as follows to YOUR machine size:
5/5.5kg machines - press Temp Up. Cold led should light.
6/6.5kg machines - press Water Up. Low water led should light.
7/7.5kg machines - press Spin Speed up. Spin hold led should light.
Power off, try a programme.
Thanks for using FixYa!
_____________________________________
From the Tech Sheet:
IWL12 and GWL 11 are different models. One of the two procedures will work for your machine.
The machine size must be set into the machine
memory if a Motor Controller or Display Module has
been changed.
To set the size:
1. Turn the power on at the power point and off
at the console.
2. IWL12 - Press and hold the FABRIC CARE
button, then press the POWER button. This
will present a set of options in the LCD
screen. The LCD screen has within it a
number of options. Push the Adjust button to
highlight the 650mm (L) machine size.
Pushing the POWER button will lock the size
into the module’s memory.
GWL11 – Press and hold the WASH TEMP
UP button then press the POWER button.
Press the SPIN SPEED UP button (the HOLD
LED should be on.)
3. Press the POWER button to return to normal
operation.
Kelly
Mar 20, 2010 | Washing Machines
It just stopped all led lights come on when powerbutton is pressed but nothing happens when the start/pause button is pressed
Hi
Thanks for using FixYa. It seems you have to replace the control board for your washer. Please do revert with the manufacturers name and model no# for your washer for further assistance.
Thanks Rylee
Feb 07, 2010 | Washing Machines
Beko Wma 765 - spin select led flashing - unable to select progra
Hi I have the same problem and am waiting to see if anyone can help too, thansk xx
Jul 10, 2009 | Washing Machines
My programmable "Carrier"
blown fuse on circuit board, or transformer dead, or hot (red) wire disconnected or broken somewhere in circuit.
Feb 16, 2009 | Carrier BCA101R Air Conditioner
Indesit1200 front loader not filling and flashing error code deno can anyone help
hi try these
There have been 3 versions of Demo Mode used on these appliances.
Version 1(Production to- Date code 39 March 2005)
To Activate
1. From the Default screen of a programme, after switching the appliance on press both Start/Cancel and On/Off buttons together until d On appears in display.
2. Press the Start/Cancel button only and tESt appears in the screen (Temp & Spin symbols also appear)
To Deactivate
Press the Start/Cancel button until all the console LED's illuminate.
Press both Start/Cancel and On/Off buttons together until
d OFF appears.
The default screen returns and you can select a new programme.
Note:- The default screen information displayed on these models is that of the programme currently selected by the selector knob.
Version 2 ( during Date Code 39 March 2005- to Date Code 42 June 2005)
To Activate
1. Same method as version 1.
To Deactivate
1. Simply press the Cancel button and the appliance returns to default.
Version 3 (During Date Code 43 June 2005 - to date )
To Activate
1. Press On/Off and Start/Cancel together with the top left option button until d On appears.
To Deactivate
1. Press On/Off and Start/Cancel toghether with top left option button until d OF appears.
Aug 22, 2008 | Indesit Washing Machines
Sharp AR-5316
Never heard of an F2 on that machine. But give this a try.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Mar 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Dryers Logo
343 people viewed this question
Top Asko Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
jimorris77
Are you an Asko Dryer Expert? Answer questions, earn points and help others
