Question about Hitachi 53UDX10B 53" Rear Projection Television
Magic focus how do you repair magic focus?
    Genius:
  • 1,153 Answers
Repair Magic focus or convergence problem? Because MF is the way you auto set your set to converg and focus.
Posted on Oct 06, 2007
SOURCE:
Set 51uwx20b, how do i fix magic flash to reset factory settings
Convergence board needs repair, google you model # and see if you can purchase a repair kit.
Nov 22, 2011 | Hitachi 51UWX20B 51" Rear Projection...
Where is the magic focus button?
Most Sony Rear Projection TV have a small door under the screen with some manual controls. Push on spring loaded door to open. Magic Focus is near the bottom and labeled.
If Magic Focus does not restore for correct operation, check the Convergence Gallery to confirm if you have a convergence fault that needs repair. #8 is the Sony menu.
[email protected]
Feb 11, 2011 | Sony KP-57WS500 57" Rear Projection...
The tv will not automatically come into focus
U have pictures out of focus?Like pictures colors seperates in lines?Ur tv convergence are dead.U know how solders?Must replaced 2 STK convergnece ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 04, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Problem with focus (severe problem on upper left
The Convergence circuit needs to be repaired.
There is a pair of Convergence IC's that need to be replaced. Best thing to do is to call a repair facility unless you have a solid back ground in Projection repair.
Hope this helps,
Skyassoc
Jul 03, 2009 | Televison & Video
Not focused
Please! Stop using the magic focus now!
There are internal parts that have failed and this requires attention by qualified personnel.
The more you hit the magic focus, the more the proper calibration points will go off the mark, since the computer only knows that the calibration is incorrect, but is unaware that the parts that DO the calibrating are defective.
Sometimes this will make the repair more difficult, since a major maual recalibration may be necessary if the registers "rolled over".
If no one had touched the magic focus and just called for repair, the set would just need the parts. Once replaced, the set would look normal. Yours will require a few more steps.
www.mcveyelectronics.com
May 03, 2009 | Hitachi 53FDX20B 53" Rear Projection...
Magic focus off
You will not be able to solve this yourself. It needs the convergence IC's replaced which is a big job.
Mar 30, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Magic focus won'f fix misalignment
YOU NEED CONVERGENCE REPAIRED EST AROUND 300.00 CALL TERRYSTV IF IN N. CALIF
Mar 28, 2009 | Hitachi 43F300 43" Rear Projection...
Will not show red color in picture, magic focus shows red though
You have a projection light element out. I had the green element go on mine. I had a service agreement so a repair tech changed it.
Feb 07, 2009 | Hitachi 43UWX10B 43" Rear Projection...
One half of picture is distorted
to create the total geometry in the tv is needed a system called Convergence.Convergence amplifiers are damaged in this unit, magic focus cannot work because magic focus works to level computer and controls the amplifiers damaged. this repair is for a technician because an adjustment is needed after the amplifier's replacement.
Oct 09, 2008 | Hitachi 61SBX59B 61" Rear Projection...
Magic Focus does not work.
Magic Focus will be restored after repairing convergence circuit.
Requires replacement of STK392-110,120 or 150 IC's with new
up-grade STK394-160 Hitachi # CZ 01341.Also,check current
limiting resistors for over-heating....Your comments,please..
.......................T.
Feb 05, 2008 | Televison & Video
Hitachi 53UDX10B 53" Rear Projection Television Logo
234 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
