Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Washer will not fill when you select col...
By samandjenjes on May 03, 2009
My Whirlpool washer will not fill when you select cold water. It will fill on warm and hot with no problems. Any ideas?
Best Solution
posted on May 03, 2009
Very Helpful)
spark9
Rank: Guru
Rating: 86%, 46 votes
Q - My washer will not fill with cold water
A - More often than not, this is a bad fill valve. Please see the filling section.
There's no cold water Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
whirlpool ultimate care ii washer LSQ9110PW2
Answer
i had the neptune maytag washer model mah6500aww.i just replaced the rubber gasket and put back... (More)
Answer
the sensor waterproof system activated; how do i fix it
Answer
the the dor lock ligth come and lock the and the fl comecome on and on water come the wasker
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in , CO
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
