Washing machine My washing machine is going through cycle and then stopping at the spinning and wont go any further and i don't no what to do I have checked the water pump its clear and it still wont work What is going on please help
  • woodiesgal Oct 10, 2007
    ive cleaned out filters and hose there is no problem there it si the timer or pump in side
    President:
  • 1,294 Answers
You have to check and clean out your outlet filter. This requires periodic cleaning, according to your usage. If its a front loader, the small door is at the front bottom, be prepared for water to come out while opening.
Posted on Oct 08, 2007
My Asko washing machine wont go into spin cycle it just keeps on washing after 3 hours I had to turn it off now what
call a technician in
the problem is most likely in the program board not progressing the wash cycle
Jul 12, 2016 | Asko W6021 Front Load Washer
Wont spin and the front indicator lights are going from pre wash to end in a night rider fashion
try checking ur door switch may also want to check the water pressure switch which signals the machine to go into wash after the fill cycle
Feb 11, 2015 | Hotpoint Aquarius WMA56 Front Load Washer
Lights keep flashing
I would check the water pump for a blockage, there could be something in the pump preventing it from doing its job as the machine cant go to the next cycle until the water has been expelled before the machine can continue eric
Jan 16, 2018 | Indesit Washing Machines
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Jan 28, 2014 | Beko Washing Machines
We have an 80 series washing machine that will go through all cycles until it is supposed to drain then nothing happens. It wont go any further .
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 29, 2011 | Kenmore Refrigerators
Hi i have an LG 5kg Fuzzy logic top loader and it will wash and fill the water but wont rinse or spin it does not beep or anything it just stops and the time displays stays on the same numbers and i can...
Need to check during the wash cycle that the power goes to the motor during the rinse or spin cycle. Try and see if you can manually go to the spin cycle without the fuzzy logic. If so the program controller unit is a suspect as the microprocessor internal memory is faulty and executes the program with error or no output.
Jan 21, 2011 | Washing Machines
My spin cycle on my maytag washing machine wont work. All else works fine but it wont drain or spin??? Please Help
check th elid switch to unit as it may have failed... it will stop the unit from going into a spin cycle and draining,,, give that a look and repost if you have anymore questions... good luck
Jan 09, 2011 | Maytag Atlantis MAV6451 Top Load Washer
The machine washes until the spin cycle then stops and will not go any further. thanks Tom
1. Water not draining away blocked filter or pump failure
2. Motor brushes need replacing
3. Load wont balance, too little or too much in the machine
Feb 16, 2010 | Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Washing Machines Logo
267 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
