Question about Linksys (WUSB54GCU) 802.11g/b Wireless Adapter
Internet conections I have a Gateway GT5086b PC and want to connect to the internet. I have ordered a home hub from BT but what do I need to enable my computer to be wireless? Thanks
Hguytguy
Posted on Dec 15, 2008
    President:
  • 2,961 Answers
You will need either a usb 54MBPS or 108MBPS wireless adapter of any make that will connect to a usb port or a pci wireless card to fit in the pc tower on the motherboard.
Posted on Oct 06, 2007
SOURCE:
Im connected to modem but not internet
Make sure internet light is green and not red. If it is not green it has not authenticated.
Mar 03, 2013 | BT 2Wire Gateway BT2700HGV Home/Office...
How do I access the internet using a BT home hub set up for wireless operation, without having to go through BTfon
Hi Graham
This should be fairly straight forward.
Your BT Home hub should be transmitting 2 signals. One called BTfon and another called something like BTHomeHub2-PGD3.
The second is what your computer should be connecting to to access the internet. If you look at the back of your home hub you will see 4 rows of numbers/text.
One should say SSID and have have the same ending as the transmitter that your computer should be seeing. Underneath that it should say WEP code or WPA. (or something similar) What follows is the password you need to enter to access that home hub's internet transmitter. The BTfon thing is for the telephone that comes with some versions of the hub - it's not for the computer.
Jun 13, 2010 | Computers & Internet
I want to change from a bt voyager 105, to a bt home hub how easy / hard to do I am not really computor minded. telboy..
It is not hard just you need to reconfigure your router WAN settings.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 01, 2010 | Computers & Internet
Hi could you tell me please how i set up a wireless connection on my bt home hub thanks
First you will need a wireless router.Once you have this you will need to take a conection from the existing hub to use as a source for the internet.Configure the router as per instruction.
Good Luck
Oct 17, 2009 | Computers & Internet
Connecting my Home Hub to Netgear to have wireless setup
3ee198b3c15f6ca7320d6cda56a651c7.png Netgear DG834G 54 Mbps Wireless ADSL Firewall Router Set-up Guide _________________________________________________________________________________________________ _________________________________
Oct 05, 2008 | NetGear DG834G Router
NH1005 network hub
I assume that besides the 2 computers you also have a cable or dsl modem connected to the hub in order to provide the actual connection to the internet.
The problem may be the fact that this is a hub and not a router or gateway. The problem is that although it will allow you connect more than 1 computer to the internet, it does not do any good if you Internet Service Provider only supplies you with 1 IP address. You need something that handles Network Address Translation (NAT), like a router or gateway device.
Sep 28, 2008 | Linksys (NH1005) 5x10/100 Mbps Networking...
Linksys (WUSB54GCU) 802.11g/b Wireless Adapter Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
