Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Problem in hard drive
I am using a samsung hard drive (size 40 GB),since last 4 yrs. Now,while working it suddenly hangs-up & there is no option left except to turn off the UPS as because neither mouse nor keyboard works. Sometimes, when i turn off the UPS, the computer doesn't turn off. one of my friend advice me to scan the hard drive completely with a new antivirus. I did so. While scaning, I found three virus, in which one was TORJEN HORSE. Then I fully format me hard drive. & re-loaded WINDOWS XP2. But, the problem still preavailing in the computer. Please, reply soon.
Plz follow the following steps : 1. First format the hard disk once again. 2. Then Partitin the hard disk once again. Make atlest 4 partition for similar space. 3. Once again instal the Windows XP software. 4. Now instal the harware drivers. 5. Defrag the system - all the partition areas. Enjoy using your computer. With kind regards,
Posted on Oct 08, 2007
  • Shamsul Huda Oct 08, 2007
    Please follow the following steps :
    1. Format your hard disk.
    2. Once again partition your hard disk. Make 3. partitions of equal size.
    4. Scan disk the drives & patch the bad sectors.
    5. Instal windows xp sp-2 in root directory.
    6. Instal the hardware drivers.
    7. Defrag the partition areas - all four.
    Happy using.
The hard disk may have some bad sectors. Try zero filling the hard disk. Try to download the programs from http://www.samsung.com/global/business/hdd/support/utilities/Support_HUTIL.html You will come to know if your hard disk is the culprit.
Posted on Oct 06, 2007
SOURCE:
Serial no 359146794305 what is its capacity
Microsoft has shipped numerous variations of the Xbox 360, with the major difference between each one being the hard drive size. As a result, your Xbox 360 can have a hard drive size as low as 4 GB and as high as 250 GB. If you're unsure of the size of your Xbox 360's hard drive, or just want to see how much space is remaining on it, you can check from the Device Options screen. This screen is accessible from the Xbox 360 dashboard when using any Gamertag.
Step 1 Select the "Settings" tab from your Xbox 360's dashboard.
Step 2 Select "System" and select "Storage" from the onscreen list.
Step 3 Highlight your hard drive from the onscreen list. By default the name of the hard drive is "Hard Drive."
Step 4 Press "Y" on the Xbox 360 controller to access the Device Options screen. The right side of the screen lists both the overall size of your hard drive under "Capacity" and the remaining amount of space under "Free Space."
Tip
  • From the Device Options screen you can also give your hard drive a custom name, clear the system cache or transfer content to another memory device.
Oct 06, 2015 | Microsoft Xbox 360 Console
How do I make 4 partition on a 40GB hard disc. What are the proceedings.
Boot up with the Windows XP installation CD
Follow the screen instructions -
Delete the existing Partition.
Create a new Partition (1st) but do not make it the maximum partition size - enter 1/4 of the maximum size.
Create another Partition (2nd) make this the same size as the 1st Create another Partition.(3rd) make this the same size as the 1st
Create another Partition (4th) make this the remaining max. size.
Format the Ist Partition Full NTSF (not quick format)
You can now proceed to install Windows on the 1st Partition.
After Windows XP has been installed and the computer's device drivers, go to Control Panel - Administrative Tools - Disk Management then allocate a drive letter to each of the Partitions then NTFS Format each of the Partitions.
Now each of the Partitions should indicated as Healthy.
Create
Dec 09, 2011 | Samsung (SP0411N) 40 GB Hard Drive
When i start my computer the problem is "hang" how can i solve it????
check the the programs u`ve installed or hardware, antivirus you have installed,defragmenting the hard disk,increase ram size,check for viruses
Aug 05, 2010 | Samsung (SP0822N) 80 GB Hard Drive
My samsung sp4002h is in an external box plugged in through a usb it was working fine and now it won't show up anywhere. When I go to use safely remove it hangs up and then says you can't end task because...
this issue could be :
1- errors or bad sector : right click >> properties >> tools >> check now ; check >> automatically check file system error + check scan for and attempt recovery for bad sector ,
be patiant until finish .
2- or replace your USB Cable.
Mar 07, 2010 | Samsung SpinPoint SP4002H 40 GB Hard Drive
Bootcode - hanaro1
Most likely drive has firmware corruption. Here's some more info.
Aug 31, 2008 | Samsung (SP0822N) 80 GB Hard Drive
HOW TO TELL A 60 GB PS3 FROM A 40 OR 80 GB
Ok a 60 gb has a chrome finish which instantly differs from the 40 gb .
The 60 gb also has 4 usb ports and a card reader slot on top that opens.. also 80 gb untis were made much later..
Open the hard drive and look on drive and it should tell you what size it is!
Jun 26, 2008 | Video Game Consoles & Games
Drive terminators
Translate from portuguese to english... Meu HD também estava com este problema, o que fiz foi limpar o contato que liga a placa lógica do HD ao leitor do disco rígido que estava oxidado. O problema ficou resolvido.
Dec 27, 2007 | Samsung (SP0411N) 40 GB Hard Drive
CMOS auto detection of samsung SP0411N HDD stops and hangs
Hi download this program its seagates diagnostic tool, put in floppy disk and run program to make a boot disk, restart pc, and let it boot off the floppy disk and it will test the drive for you... http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=DiscWizard&vgnextoid=d9fd4a3cdde5c010VgnVCM100000dd04090aRCRD All the best john
Feb 16, 2007 | Samsung (SP0411N) 40 GB Hard Drive
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
66 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
