Question about De Dietrich DOC310 Electric Single Oven
Removal of door
The inside of the oven glass is dirty and I cannot get between the glass and the door. Can anyone tell me how to remove the door or glass for cleaning please? Thanks Peter
  • 4 more comments
  • AnnL Dec 30, 2007
    I have exactly the same problem on the lower door of my double de Dietrich oven [model DOD438B] and would very much like a solution
  • JohnBoy H Dec 02, 2008
    I have the same problem on my De Dietrich DOD718x oven. I can see a substantial gap between the glass and the top edge of the door where the fat or grease can run down the inside. Looks like a design fault. I can't see anywhere to release the glass for cleanig though. How frustrating, the ovens only three weeks old and already needs cleaning on the inside of glass. What's it going to be like in a years time?
  • jimmyts Jan 06, 2009
    My oven is threee years old and I have the same problem. Is there really a special key?
  • Anonymous Mar 15, 2014
    How to remove glass from oven door
  • Anonymous Mar 17, 2014
    how to remove the inner glass door so that i can clean both glass doors
  • Anonymous Mar 22, 2014
    Cleaning between the glass door
Get a special key and open
Posted on Nov 13, 2007
Removal and disassembly of oven door
The panels on the door , specially the glass panels can be removed easily if care is taken to remove the fitting screws.
You can use a good cleaner glass cleaner to remove any dirt that has deposited on the frame and glass panels.
Once the glass is dry it can be refitted , care taken to use gloves so as to avoid hand impressions .
Dec 06, 2011 | Fisher and Paykel Ovens
Dripped inside top of oven door. Need to clean the glass inside door.
you will have to remove door and the inner part of door comes apart... be careful there is more glass inside than you really can tell... lay the unit on a rug or something once you have it removed and disassemble ... fairly easy process. requires just a couple of tools and a little patience.....
Jan 05, 2011 | Ovens
Yesterday I cleaned my inside glass of my cooker (moffat94971100) The sealant popped and I have a loose glass. I have found sealant however how do I get the door off and weigh down the glass is there any...
Hi.
Normally there is a clip on both door hinges to allow easy door removal.
Once door is removed place on a towel on a flat surface. You will find a couple of screws on the top of the door and possibly underneath. Unscrew these and the two halves of the door should come appart. The inner glass is held in place with high temperatute oven sealant. You will need to thoroughly scrape the old sealant from inside inner door and on glass.
Apply sealant bead to inner door (but not too close to the edge) and then gently lower the cleaned glass on to the sealant. Press down gently. Now the sealant must have 24hrs to completely set so place a towel over the glass and place some heavy objects on the towel. House bricks are good if you have any.
Once dry you can then screw both door panels together and refit oven door.
Regards
Aardvark Repairs
Nov 16, 2009 | Ovens
I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
Oct 10, 2009 | Kenmore Ovens
Dirty streaks between glass front
depends on type of unit,but most separate by opening oven door and removing the screws around the perimeter of the door, be careful reinstalling as to get inner and outer glass re-positioned right along with insulation,this is especially critical because the outer glass can't withstand self-clean temps and will break
Aug 22, 2009 | Ovens
Need to clean the inside of glass on maytag's oven precision 500.
I have a GE range. The oven has a glass window. There are an inside and an outside glass. Somehow the inside of the two glases has gotten dirty. How can I clean this? Can I take the door apart? Thanks
Apr 25, 2009 | Ovens
Zanussi Oven inside glass problem
Hi , i removed the door, and removed two small screws from the bottom of the door,you can the seperate the door into two pieces by slidng them apart,cleaned up the glass,bought a tube of heat resistant silicone and put some around the edges of the door and glass. I then replaced the glass,i left overnight to set and rebuilt the door.
Regards
Eddie
Jan 27, 2009 | Ovens
Smeg 90cm oven - removing inner glass plate of door
First you have to unmount the door from your oven (descriped in the manual how to do).
Then next, remove the screws that you have mentioned already of the inside of the door (the inner glass plate is mounted by adhesive on the outer part of the door). After yo have removed the screws, the inner door can be parted from the outer door. Wupti - now you are able to clean the inner side of the glass platen of the oven door.
Per Oding, Denmark
Jan 06, 2009 | Ovens
Jenn air double ovens
First, with the door closed, find the screws at the bottom of the door and remove. With an assistant, open the door and remove any side and inside screws you find. The door will separate into two halves. Be aware that most glass is not clipped in...they can fall and break. Remove the front panel from the door...the door may try to slam shut. To clean the glass, use a blue cleaner and a scrubby or very fine steel wool rubbing gently. Scratches are not allowed! Take pictures of what you're doing so you can replace. Be careful of brittle door insulation.
Oct 30, 2007 | Jenn-Air JJW8230D Electric Double Oven
De Dietrich DOC310 Electric Single Oven Logo
1,282 people viewed this question
Top De Dietrich Ovens Experts
Marvin
Marvin
ray gallant
Harry Reinhardt
Level 1 Expert
Are you a De Dietrich Oven Expert? Answer questions, earn points and help others
