SOURCE: Maytag microwave
Your membrane keypad is failing.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: Microwave is not getting power
may i please ask you if you have a meter? check that 120 volts is going in? check the buttons that you press. also check the fuse check the mains cable for any breaks. also you may want to test the display to see if any power going in?
SOURCE: Maytag Microwave, Model MMV5000BAB. Discrepancies
remove the outer cover and unplug unit,then discharge the high voltage capacitor and check its capacitance with a capacitor checker,then check the high voltage diode in this circuit also,if they open up the high voltage doubler circuit won't produce the high voltage necessary to operate the magnetron tube to heat the food contents,also the magnetron can be going bad or can be loose setting up a vibration in the unit producing the hum also,your control board also has a relay in this unit that can also affect operation of unit heating and lighting
