Question about Sony Ericsson W600i Cellular Phone
Loose phone my phone has become loose and shaky....it also now turns in both directions
Isn't it supposed to turn both directions though?
Posted on Jan 28, 2008
  • 456 Answers
Ohh open ur phone and fit it again its problem of loose screws
Posted on Nov 28, 2007
SOURCE:
How do I fix lid on HP Pavilion M6-1009TX notebook laptop ?
In this case, i recommend you to bring your laptop to any service centres around and ask for part replecement.
Yes, the hinges are loose. It is a well known issues for laptop users. Frequent opening and closing behaviour can cause the wear and tear effect become even more apparent.
But if you really want to do it by yourself, then you should prepare a few things.
1) The hinges specifically for your model.
2) Set of screwdrivers for your laptop
3) Another laptop / tablet/ phone that can be used while you open up the laptop.
From there, you can search the youtube for hinge replacement. Take note of the number of parts and screws you took out. Opening it would be easy but putting it back in place is hell of a mess. Take a note and be organized while doing it. We don't want the keyboard to be loose after this wouldn't we?
Good luck.
Aug 20, 2014 | HP Pavilion Computers & Internet
When I flip the manual switch it clicks but the lights wont turn on.
Manual override should turn lights ON-OFF even if timer has gone bad.
It sounds like problem is electrical.
Suspect line-up:
Test that timer is getting electricity from breaker.
Burned out bulb. Change bulbs. Spray WD-40 on bulb threads before installing bulb.
Outdoor wiring can go bad easily, outdoor bulb sockets become dirty and stop functioning.
Loose wire between breaker and timer -or- between timer and lights.
Loose wire inside timer box. Tighten screws.
Loose wire on circuit breaker. Tighten screw on circuit breaker.
Tripped circuit breaker: click circuit breaker all the way one direction and then all the way back other direction.
Bad circuit breaker. Move wire from one breaker to another same-size breaker.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 20, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Steering is shaky
If you mean shaky when applying brakes, turn the front brake rotors. If you mean shaky when turning the steering wheel, check to see that the power steering belt is slipping.
Sep 22, 2010 | 1999 Dodge Ram
Screen goes all shaky and white for short intervals of time.
Try installing the video drivers from HP's site.
Sep 22, 2009 | Compaq Presario Notebook
Blurry shaky pic
It sound like you have a leaky capacitor in your power supply, or video circuit, that is causing noise in the picture. I would have to refer you to a television technician in your area. This would seem like a simple repair. Leaky capacitors can become stable after they warm up.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
May 01, 2009 | Toshiba 50H81 50" Rear Projection...
Screen is dim on the home screen
loose flex cable,happens when phone gets dropped ,open it ,reinstall ribbon cable,turn on,check,close it back up.
Feb 03, 2009 | Motorola Mobility RAZR V3
Shaky/Unstable Picture
This is power supply issue, one or more of your filter capacitors either bursted and/Or over heats (this is why it becomes better when system cools down after turning it off for 1/2 hour..You have two choices.1. buy a replacement power supply may set you back a couple hundred dollars but it will be plug and play. 2nd you can replace these filter capacitors make sure the can handle 105 deg celsius not the 85 deg. celsius, if you know how to trace the bad ones and desolder and solder new ones on the power supply board, or hire a techinician to replace them for you. Good Luck...
Dec 14, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Shaky Picture only during Advertisement or... Mitsubishi SC 27403
If you have cable then put the cable wire directly in the TV, bypassing the cable box. If the pix is Ok it proves that the problem is the cable box. If the problem is still there then it proves the the TV needs parts inside.
Mar 24, 2008 | Televison & Video
Blurry pictures
try having other people take a picture with your phone, if they can take a more clear picture, it is likely that you are just a little shaky when taking pictures (i have the same problem)
Jan 31, 2008 | Motorola Mobility L6 Cellular Phone
Sony Ericsson W600i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
