Question about HP DeskJet F380 All-In-One Printer
Printer printing lightly every second line
Not helpful as there is no 'head cleaning' or clean printer head under properties. Is this because I use Firefox if so where would this else can I look?
  • kezz_r1 Oct 08, 2007
    I couldn't find the website but when I do I will let you know if it helps.
    Novelist:
    Scholar:
  • 167 Answers
Just try to get help from your printer manufaturer's webite. As this way you would get most accurate information.
Posted on Oct 06, 2007
When printing/copying, it does not print completely, it is like it misses printing every second line
Your inkjets are partially clogged.
First, from a computer, go to Properties for the printer and choose deep cleaning.
You can also run a Print Head Nozzle test from there. If that doesn't work, remove the ink cartridges and then the print heads and run them under hot running water until the water runs clear. Shake the water off and pat dry with kitchen towel. Reinstall and try printing again.
Oct 03, 2015 | Canon PIXMA MX340 Wireless Office...
Having problem printing. Print out has vertical white lines. Help!
Try changing the ink cartridges. Also clean the print heads. Go to printer properties, maintenance, clean print heads.
Jun 08, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
I just replaced all the inks in my printer. When I try and print only every couple of lines print. what should I do
Hi Good day!! Maybe you need to clean the head. to do that you need to do the head cleaning.
here are the step:
1. Click "Start
2. Choose "Setting" and then "Printer and Faxes" you should see your printer installed.
3. right click your printer and then properties you should be on the printer properties box
4. Click "Printing Preferences" now you should be on the Printing preferences box. there are 5 tabs go to the "Maintenance tab"
5. Select "Head Cleaning. and then you can start the cleaning of your printer head..
after you clean it try to print again and see if your printing was fine if not you should clean it again back to start.. .
Hope my solution helps you..
Regards
JR
Oct 08, 2010 | Epson Stylus Photo R260 InkJet Printer
Printing is fuzzy.
try doing head alignment, this feature is located under the printer properties... goto Start, then Setting, then Printer and faxes, and point to the printer model, right click and select Properties... then select Maintenance and from there, you can clean head and head alignment... print the alignment sheet and select the best straight line.. that should help.
May 26, 2010 | Canon PIXMA MP470 All-in-One Printer
My r290 add red color to my photos
*** I'll be more than happy to help you on that. you might be talking about R280, because theres no R290 for epson. there is a great possibility thatsome of the nozzles of your printer are clogged by dried inks, thats why when it prints, the inks are not equally distributed or is not balanced.to check that, print a nozzle check, and if you see gaps or breaks, between the lines, do head cleaning. this is how you can do it, its very easy for you. Using the Buttons on the Printer 1. Make sure the printer is turned on but not printing, that the CD/DVD tray is not inserted in the printer, and the red maint.5.1.8.jpg ink light is not on. (If the red maint.5.1.9.jpg ink light is on, you need to replace a cartridge.) 2. Turn the printer off and make sure the front tray is in the paper (lower) position. 3. Make sure letter-size plain paper is loaded in the printer. 4. Hold down the maint.5.1.10.jpg paper button, then press the maint.5.1.11.jpg power button. Hold down both buttons until the maint.5.1.12.jpg power light begins to flash, then release the maint.5.1.13.jpg power button. maint.5.1.14.jpg 5. When the nozzle check starts to print release the maint.5.1.15.jpg paper button. Check the nozzle check pattern that prints to see if there are gaps in the lines. maint.5.1.16.jpg 6. If there are no gaps or lines, the print head does not need to be cleaned. If there are gaps or lines, or the test patterns are faint, follow the steps in do the Head Cleaning to clean the nozzles. Using the Buttons on the Printer 1. Make sure the printer is turned on but not printing, and the red maint.5.1.23.jpg ink light is off. (If the red maint.5.1.24.jpg ink light is flashing or on, you need to replace a cartridge.) 2. Hold down the maint.5.1.25.jpg ink button on the printer for approximately 3 seconds. The printer runs a head cleaning cycle and the green maint.5.1.26.jpg power light flashes. Cleaning takes several seconds. Caution:
Never turn off the printer while head cleaning is in progress. You may damage it.
Do not insert the CD/DVD tray until cleaning has finished. 3. When the green maint.5.1.27.jpg power light stops flashing, make sure paper is loaded in the printer, then print a nozzle check to determine whether you need to clean the print head again. Print Head Nozzles If you don’t see any improvement after cleaning three times, turn the printer off and wait overnight. This allows any dried ink to soften. Then, try cleaning the print head again.
Feb 16, 2010 | Epson Stylus R290 InkJet Printer
Help. Cannot print from black ink cartridge
Hi ....
There could be many reason for black ink not printing. You could try couple of steps starting with cleaning the print head ... Follow the below steps to clean the print head ...
After confirming that the cable is connected (if applicable) and the printer is powered on, perform the following.
Note: Standard print head cleaning can also be performed by holding down the <Resume> on the printer until the power light flashes one time. Deep print head cleaning (a more power process that uses more ink) can only be performed from the computer.
  1. Open the Printers folder.
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
  2. Right-click the printer icon and select 'Properties'.
  3. Click the Maintenance tab, and then click the 'Cleaning' icon.
  4. Select which nozzles should be cleaned.
  5. Click 'OK' to continue with the print head cleaning. The power lamp will flash and print head cleaning will start. Do not perform any other operations until print head cleaning completes.
  6. When the print head cleaning has finished, print the nozzle check pattern by clicking on the 'OK' button to determine if further cleaning is necessary.
  7. Once the page has printed examine the nozzle check pattern.
  8. If the pattern does not print correctly, click the 'OK' button to return to the Maintenance tab.
  9. Click the 'Deep Cleaning' icon.
  10. Click the 'Execute' button after selecting the nozzles to be cleaned.
  11. Confirm the message, and then click the 'OK' button to start the Deep cleaning.
  12. The Power lamp will blink and print head deep cleaning will start. Deep cleaning completes when the Power lamp stops blinking and lights. (It will take about a minute for the Power lamp to stop blinking and light solid.)
  13. Print another nozzle test pattern. If the pattern still does not print correctly, replace any ink tank that may be low, and then perform another deep print head cleaning.
  14. If printing is still not satisfactory, there may be a problem with the print head or the printer may need to be repaired.
This resolves the problem most of the time but if this does not work, please just leave me a note and we'll move to the next step which is checking the cartridge installation to check if its inctalled correctly or not ....
Please vote if this helps .... Cheers :)
Aug 04, 2009 | Canon PIXMA iP90 Mobile Printer
Need to clean print head. some lines are blurred
The following solution is under the assumption you have installed the complete software via the supplied CD with your Epson Printer.
Windows:
Right-click the printer icon on your taskbar (in the lower right corner of your screen).
Select Head Cleaning.
Note:
If you don’t see the icon, go to your printer properties window and click the Maintenance tab, then select Head Cleaning.
The link to your Printer Documentation / Drivers:
www.epson.com
Select Drivers & Support
Jun 17, 2009 | Epson Stylus C88 InkJet Photo Printer
Canon mp600 won't print every line
hi! there if streak came to your printed paper,try to go on maintenance menu.doing this left click crontol panel and then click your priter,on printer left click and click properties then click maintenance,on maintenance click clean,make it several time then click pattern test if this acquired quality print,if theres problem try the deep cleaning observe there are much ink to consume in deep cleaning,don,t try to clean your print head w/c not recommend on your manual,otherwise you will damage your printer head,if still streak bring this to your cannon service center to check printer head status,regads and havw a nice day thank's.
Mar 28, 2009 | Canon PIXMA MP600 all-In-One InkJet...
HP D5360
Have you tried running the head cleaning in the maintenance section of your print driver? If the lines are clogged it will not print anything, also if ctg has just been changed make sure all packing has been removed. lots of times there is clear tape covering the bottom of ctg so it doesn't dry out when in package. Running the cleaning tool a few times forces in thru the lines and the print head. Usually under the properties of driver, (right click driver and select properties) then find maintanence tab.
Hope that helps
TankMurdock
Dec 09, 2008 | HP Photosmart D5360 Printer
Lines on printed photos
Hi Have you tried cleaning the printer and doing a alignment for the inkjets? I believe under your printer properties you should have the option do to maintenance clean and alignment>when doing this it will use some ink but in order for the printer to function properly you sometimes have to do this. Hi hope this helps you!!
Dec 04, 2007 | Office Equipment & Supplies
HP DeskJet F380 All-In-One Printer Logo
90 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
