Avr-1705 full volume burning loudspeakers
    New Friend:
My Harman Kardon AVR-130 volume decreses 45 min to 1 hrs after been turned on. Can you advise please.
Posted on Feb 12, 2010
    New Friend:
  • 101 Answers
Check the impedence you amp.s ohms or probably lower then the speakers you are using.alower ohm amp will blow a higher impedence speaker.a lower ohm speaker will burn a higheer ohm amp.make sure ur amp. n spkrs are the same impedence.
Posted on Jan 21, 2008
  • 93 Answers
So, what seems to be the problem?
Posted on Oct 08, 2007
SOURCE:
My denon got broken front panel, can i order a new front panel including the plexiglass?
I have service manual of Denon AVR-1705 that has part number list, schematics etc
I'll upload that service manual for you to take part numbers of broken parts in receiver and check it out at partstore.com
Let me know if you need service manual copy.
Thanks.
Nov 27, 2010 | Denon AVR-1705 Receiver
I have a Denon AVR 1705 and can get a tv picture and no sound or sound with no picture. Is there a setting or selection that I am missing to have both.
Sounds like the sound inputs have been reassigned to another input-
You'll ideally need the instructions to give a fuller idea of how you adjust these and all the options it gives you
Sep 03, 2010 | Denon AVR-1705 Receiver
Video does not work All this while, I had never used the video components of my AVR 1705. Recently, i wanted to connect the component out of the cable set top box and dvd player to the avr and the output...
Hi
The settings on many DVD players and TVs may need to be set to indicate the type of input/output being used(RGB vs YUV/YPbPr, and if set wrong the image may not be properly displayed. Try Look for such settings in your TV and/or Amp!
Good luck
Bruce
Dec 07, 2009 | Denon AVR-1705 Receiver
Denon AVR-1705 Missing Video Functions?
What you need to do is connect all your devices to the Denon Using the best connections (Yellow Video=OK, S-Video=good, Component green-red-blue=better and HDMI=best. if you do not have a DVD that upconverts to 1080i or p when using HDMI, I would use component cables where available from your devices to the Denon other wise use the next best connection available and if connecting digital audio make a chart of all connection so you can setup everything when your ready for programming the Denon
Feb 11, 2009 | Denon AVR-1705 Receiver
Denon AVR 1705-no audio on TV
I have had the same problem and was told that it is a "board" inside. Essentially it has lost the surround sound ability and can only play things in Direct/Stereo. Mine is just over 2 years and I originally thought my kids had hit a button on the thing causing the issue...ended up paying $100 to trouble shoot it and confirm that it is internal and more expensive to fix than replace. Can't say that I will be buying a Denon again.
Jul 09, 2008 | Denon AVR-1705 Receiver
Denon AVR-1705 won't power up
when i turn it on it stays on for 3-4 seconds then shuts down
Jun 27, 2008 | Denon AVR-1705 Receiver
Volume
Volume control
• When you have an active call or are listening to a sound, press o) or (o to
increase or decrease the volume level, respectively.
Voice volume icons:
- for earpiece mode,
- for loudspeaker mode.
Loudspeaker
Your phone has a loudspeaker for handsfree use. The loudspeaker allows you to
speak and listen to the phone from a short distance without having to hold the
phone to your ear, for example, having it on a table nearby. The loudspeaker can
be used during a call, with sound and video applications, and when viewing
multimedia messages. Sound and video applications use the loudspeaker by
default. Using the loudspeaker makes it easier to use other applications while in a
call.
Apr 02, 2008 | Nokia 6600
DENON AVR 2802 (NO SOUND)
If "Digital" sign blink on front panel, it means DSP do no start properly. If DSP do not start, main UC mute audio. Change IC, AT49LV002-70TC (IC 817 ) at DSP board (Denon P/N: 262 3010 006).
Jan 01, 2007 | Denon AVR-2802
 Grubhead
Grubhead
Marvin
Marvin
