Question about Nokia 7360 Cellular Phone
How to solve this one? Help me!
My phone hang up in just a second then it turn on with a message " insert sim card"... Men. I cant use my cell phone properly... It's very annoying.. Help me... PLEASE..............
  • 490 Answers
Sim card slot is not working properly.change that frm nokia care and try....after restoring...pls,have a back up of ur data.
Posted on Oct 16, 2007
SOURCE:
I have samsung virgin mobile model no.SCH-B309 but sim shows that uim card rejected what can i do sir please help me and provide me uim no..
you can solve your problem easily,your uim card which is rejected by sim :firstly your uim card insert correctly or not secondly your sim card placed correctly or not if not both you insert the card correctly otherwise your must be phone off because sometimes phone hanged.
Mar 24, 2013 | Samsung SCH Cell Phones
Insert sim card is found in low signal
First:
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Second:
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Jan 12, 2013 | Samsung GT C5130 Mobile
Hanging the phone n72 when insert sim card.
Your phone had a network ic i think it is the culprit here replace it with new one
Feb 18, 2012 | Nokia N72 Cellular Phone
My phone shows "please insert
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
Jan 15, 2011 | Cell Phones
I have nokia n70 but i cannot received and sent text messages nor cannot make a call keep saying network busy. please help me this.
1. Turn the mobile phone off for a second and turn on, check if you have network signal. If still not working, try #2
2. Turn off the phone and remove the battery and sim from the phone for a couple of second. Return everything and turn on the phone. If still no network or no signal from you network provider, try #3
3. Turn off the phone and remove the battery and sim from the phone, insert the sim card to your other phone and check if you can make and receive calls and text messages.
4. Insert a your other sim card from your phone and check if you can do the same.
**With this, you can identify what needs to be repaired or replaced. (Sim card or Mobile Phone). If you cannot make and receive calls and text messages using no. 3 method, it is the sim card that has the problem and needs to be replaced. But if with #4, the phone has the problem and not the sim card. You need to contact your Service/Network Provider from technical help.
Thank you.
Aug 10, 2010 | Nokia N70 Cellular Phone
My pantech matrix cell phone says insert sim card
This problem arises sometimes because the mobile is unable to read the SIM. May be you should fold a small piece of paper in the same size of the SIM and keep it on top of the SIM and then insert the Battery. I think this will solve your problem.
Jul 21, 2010 | Pantech Matrix Cell Phone
I can't turn off the SIM Lock
Hello, Please get the PUK code on your service provider,
Kind Regards, Jay
Oct 05, 2009 | Nokia 5310 Cellular Phone
I cant send text messages
Hi..
Check for the correct Message centre number in the message settings. After its been verified the correct number, switch of the phone, remove sim card from phone for 10 minutes and then insert it again and start the phone. You can find the problem is been solved.
Feb 25, 2009 | Nokia 3230 Cellular Phone
Please insert SIM
dear,
If the phone freezes
  1. Press and hold the on/off key.
  2. If your phone does not power down, remove the battery for 10 seconds, insert it again, and restart the phone.
Note: Use The Sony Ericsson Update Service regularly to reduce the risk of software problems. Make regular backups using Sony Ericsson PC Suite to reduce the risk of lost or corrupted information.
dont forget to rate me.
regards,
Jul 29, 2008 | Sony Ericsson K300i Cellular Phone
Insert SIM Card
make sure the sim card can make good contact with the phone.
Also check if it doesn't have space to slide, causing it to loose contact with the phone.
Mar 27, 2008 | Nokia 6270 Cellular Phone
Nokia 7360 Cellular Phone Logo
59 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
ASHRAF CA
ASHRAF CA
