Generator good but i have only 5 volts comming from generator rec. checked all wiring everthing look great.
SOURCE: My porter cable generator 3000 wt will not stay running once star
If this generator has been stored for any length of time with fuel in the carb you probably have a plugged main jet in the carb. As joboo1 says there are a few other things that could cause this behavior, but most often I see dirty carbs, water in the fuel, and plugged/dirty air filters. Get a flashlight and look into the fuel tank thru the filler hole, if you see anything floating in there you've got water in the fuel. Look at the ari cleaner, oil and fuel on the element indicate a dirty carb. Of course check the oil level. Lastly, take the bowl off the bottom of the carb (shut off the fuel valve first), if you see debris in there the carb needs a good cleaning.
Regards,
Carl
SOURCE: no electricity from generator
If you have a voltmeter, you can check the voltage coming out of the outlet. If you have some kind of residual voltage, such as 25 Volts AC or 10 volts ac, then you probably have a voltage regulator problem and your regulator will need to be replaced. If you read 0 volts then you you have an open between the output (outlet) and the windings of the stator.
SOURCE: Porter Cable Generator does not produce electricity
Here are a a few possibilities to look at:
1) Bad connection at the outlets themselves (loose wire) regarding neutral, hot wires.
2) Bad Excitation Capacitor. The Exc. Cap. is responsible for energizing the field wiring of the alternator. If the field is not energized, there will not be a magnetic field developed, therefore, no electrical output.
3) Open Field / Stator winding. If Field winding is open, no magnetic field will be developed. If Stator winding is open, no voltage will be induced.
4) Generator speed is too slow. If the RPMs of the engine are too slow, the output of the alternator will fail as well. Note that from normal speed, voltage output will occur but at reducing frequency until ouput ceases altogether, usually at about 47Hz. If your alternator is a 2 pole, engine speed should be 3600 rpm nominal. If alternator is a 4 pole (most aren't), engine speed would need to be about 1800 rpm nominal.
5) Generator speed too fast. If RPMs are too fast, output may fail as well. See above.
6) Excitation Fuse has blown. There is sometimes a fuse in the excitation circuit. To check this, you will likely need to pull the end housing off the alternator. Pay attention to bearings / bushings.
SOURCE: porter Cable T5500 generator - engine racing - no
Have you checked to see if the breakers have tripped?
SOURCE: runs good but no generatoring would like service
Easy enough.. here is link:
http://servicenet.deltaportercable.com/Products/Detail?isId=true&productNumber=BSV550-W&selectedType=14778#
Good luck with it and let us know if you nned more specific help
Thanks
