Question about D-Link DI-707P Router (DSDLDI707P)
Emule lowid Sir I have Microsoft window Vista home premium and Norton Internet security. In Emule I am getting LowId. I have opted for Norton Firewall. But I have configuered in Both window Vista and NIS firewall to allow Emule. I have a Broad band connection of Qtel in Qatar. I have also tried to change TCP & UDP port but nothing has worked. Kindly guide with steps how to overcome the LowiD Problem. Regards R K RASTOGI
I have Vista 32 and after consulting PortForward.com I opened the ports and _tried_ to set up a static IP-address, no matter what it's I cant get a static one!
But for some reason, I sometimes geot High ID at eMule. But since today, it's low id again...
And yes, I noticed, that this topic is half a year old
Posted on May 29, 2008
Dear Axys
   I disabled firewall. still it shows LOW ID.
Ravi Kumar Rastogi
Posted on Oct 13, 2007
  • 49 Answers
Firewall should be disabled for it to worked . if not it should be set into some settings that is not too secured enough. because even f you try to open the ports, it will not work if something is still blocking that.
    Scholar:
  • 26 Answers
I am sorry, but I would not listen to advice that you need to disable your Firewall for it to work!?!
Obviously as the response shows, even with the Firewall disabled it did not work [and would be vulnerable to attack]
There are two possibilities off hand:
  1. You have not taken into account forwarding ports in your Router as well as Software Firewall [if applies to you]
  2. Your ISP may be aware of using the ed2k protocol and try to stop you from using eMule
Remember to use the OBFUSCATION option.
This option in eMule allows you to connect to a server in a way
that masks or 'hides' the ed2k (eMule) protocol
Go To Options > Security
Here you'll tick the "Enable Protocol Obfuscation" box
Remember to only tick the first box under "Protocol Obfuscation"
You should be able to see your 'hidden' status on the right side
of the server window in eMule
If your ISP was in fact interfering, this should help you gain back your ability to use eMule without restriction
Posted on Feb 20, 2008
SOURCE:
Activation key problem for norton assurance
There are other free Antivirus, Norton just slows your machine down, I suggest two of the following: Microsoft Security Essentials, and Spybot S&D 2
Oct 02, 2013 | Microsoft Windows? Vista Home Premium...
How to fix error code 646 microsoft windows vista home premium software
* The solution, in a nutshell, is to disable your firewall. If you’re using McAfee Personal Firewall Plus, F-Secure Internet Security, Norton Internet Security or another Firewall vendor, see its respective support page for assistance in disabling it (temporarily). If you’re using the built-in Vista Firewall, keep reading.
* Open the Control Panel and select Security.
* Select Turn Windows Firewall on or off.
* Select Off (not recommended), click Apply and then OK.
* Back at the Windows Update screen, click the Try again button.
* The download(s) and installation should start…
* and this time successfully install. If a restart is required, make sure to re-enable your Firewall once your PC restarts.
* Though this solution will work for most Vista Update errors
Jun 24, 2010 | Microsoft Windows? Vista Home Premium...
Error code 646
Hello Titan,
Try to disable your firewall. If you’re using McAfee Personal Firewall Plus, F-Secure Internet Security, Norton Internet Security or another Firewall vendor, see its respective support page for assistance in disabling it (temporarily). If you’re using the built-in Vista Firewall, keep reading.
Regards,
Soul_srch007
Dec 19, 2009 | Microsoft Windows 98 Year 2000 Update for...
I have windows vista,when I try and do the windows update I keep getting error code 646 and they are not installing,is there a free and easy way of correcting this as I am on a disability and do not have...
Dec 13, 2009 | Microsoft Windows Vista Home Basic Edition...
I cannot download the new windows updates-I get an error message 646 and cannot find out what that means
Try the following steps to install the update successfully.
Stop the services pertaining to Windows Update.
1. Click Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.
2. If you receive a notification from User Account Control simply click Continue.
3. At the command prompt, type the following commands and then press ENTER after each command.
net stop wuauserv
net stop bits
net stop cryptsvc
4. Please do not close the Command Prompt window.
Rename folders pertaining to Windows Update
At the command prompt, type the following commands and then press Enter after each command:
ren %systemroot%\System32\Catroot2 Catroot2.old
ren %systemroot%\SoftwareDistribution SoftwareDistribution.old
Start services pertaining to Windows Update.
net start wuauserv
net start bits
net start cryptsvc
Close the Command Prompt window.
Download the standalone package file of the update “KB967043”
and install it.
Visit the following link to download the update:
http://www.microsoft.com/downloads/details.aspx?familyid=628280fe-e035-4274-85f2-393d9bad543c&displaylang=en
Restart the computer once the update is installed.
Let me know if this worked.
Oct 15, 2009 | Microsoft Windows Vista Home Premium with...
I'm having trouble getting a Vista Home Premium laptop to connect to websites (ex. google, yahoo, etc.). I am able to connect to my home network and with an alltel wireless network card. Vista says that it...
On your mozilla browser try clicking tools, then options, under advance, click network. Under network you would see settings click it. And click auto detection of proxy setting. And click ok right after. This should do
Aug 10, 2009 | Microsoft Windows? Vista Home Premium...
"Project1 has stopped working"
The issue definitely is associated with Norton. I have Norton Internet 2009. To get rid of the error, the following needs to be done.
* Right Click on the Norton Protection Center Icon from the system tray
* Select Norton Internet Security
* Click Settings
* Under Basic Security, click Auto-Protect
* Click Configure
* Under Real-Time Protection, take the checkmark off "Turn on scanning for Micorsoft Office documents"
Jul 29, 2009 | Microsoft Windows Vista Home Premium with...
I wish to install Windows Vista Home Premium. I already have Windows XP. I pay for Norton Internet Security by direct debit through Tiscali and have done so since, 2006. I have run Norton Liveupdate. ...
You will need to cancel your Norton subscription and use one of their products that is suitable for Vista. May I suggest that you purchase Norton Internet security 2009 for a single payment of about 70 dollars.
Dec 11, 2008 | Computers & Internet
I cannot open ports TCP/UDP for eMule using router 2Wire Infinitu
You need to portforward your router to accept emules port number/numbers. Go to portforward.com. look up your router and follow the instructions. It's pretty easy.
Nov 28, 2008 | Xincom XC-DPG602 Router (XCDPG602)
IPAC PDA rz1710 and Vista
If you are running ActiveSync 4.0 or later and personal firewall software on your personal computer, please add ActiveSync to the firewall program’s exception list. (Firewall software, such as Sygate Personal Firewall, TrendMicro PC-cillin Internet Security 2005, Norton Personal Firewall, McAfee Personal Firewall, or Zone Alarm Security Suite may block synchronization.) Refer to the documentation that came with your firewall program to determine how to add ActiveSync 4.0 or later to the program’s exception list. To further troubleshoot a firewall application and enable ActiveSync 4.0 or later
Jul 08, 2008 | Microsoft Windows Vista Ultimate Edition
Open Questions:
See all D-Link DI-707P Router (DSDLDI707P) Questions
D-Link DI-707P Router (DSDLDI707P) Logo
926 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
