Question about Welbilt MR755T Microwave Oven
No heat my micro is not heating model#MR757T
  • Blondzilla Apr 14, 2008
    The light flashes on and off, makes sounds like it's turning on and off.
    thanks, Alice
  • 473 Answers
Most common causes for no heat is bad magnatron, capacitor, or diode. This should be checked by a certified technician due to high voltage. Microwaves come with a 1 yr warranty from date of purchase and in some models the warranty is longer on the maganatron. Will need to check the owners manual.
Posted on Oct 07, 2007
MW1030WA 1000 Watts Microwave Oven: Not getting full heating effect. Heating effect re...
If there are no bangs or arcing taking place and simply the heating output is slow, then it would be a matter of replacing the magnatron. Once the micro cover is removed,the magnatron is that square module sitting half way up bolted on with 4 small screws. Quote the model on the sticker stuck on the MAG. and order a new one. Take care when replacing. Lage voltages present on capacitor.
May 18, 2010 | Samsung MW1030WA Microwave Oven
Heat doesn't come on in microwave
If you have the experience with discharging a capacitor and you have a (VOM) Volt Olm Meter. Unplug microwave, discharge capacitor, and check the resistance of the two thermal cut-off discs by removing the lead and set VOM to RX1. If you don't get a reading of zero, replace the discs. For part go to www.partselect.com and enter your model number. If you found any of these suggestions helpful, please rate my solution. D. Lange
May 01, 2009 | Microwave Ovens
My micro wont heat the food but everything else seems ok
I have a GE Spacemaker Microwave, model # JVM1650WB008
The lights work and everything runs in a normal operation, it will not heat the food. I have changed the fuse and still the same, no heat.
Oct 05, 2008 | Microwave Ovens
Goldstar MV-1501 1000 Watts... Problem:
if micro. new then its defective
if micro. old then you need replacement or service the heating element and turn table motor
Jun 02, 2008 | Goldstar MV-1501 Microwave Oven
Microwave made a loud pop,won't heat,sounds like it's only on half power, makes a low intermittent hum
This is almost certainly a blown high voltage diode.
Please reply back with your brand and model number so we can help you.
May 31, 2008 | Microwave Ovens
Not heating
Normally the fuse(s) in a microwave will kill all power to the unit and render it "dead", as opposed to just limiting operation. The most common causes for it to run without heating are a bad door switch, a bad relay or connection on the control circuit, a bad connection on the "FA" magnetron terminal, a defective high-voltage transformer, a defective magnetron or a shorted high-voltage diode. One thing you could do is to try gently pushing down on the door handle or the door about 1/32 of an inch or so and se if it heats then. That would indicate door switch trouble or alignment. This test can easily give you a false "positive", though. I hesistate to offer any more specific instructions unless someone is an experienced and informed DIYer or more. Even still, I would want to steer a person toward my Web site, which contains important safety info and free DIY tips. But I cannot, since such a referral would violate the terms of this site.
Oct 07, 2006 | Samsung SMH7174BC Microwave Oven
Microwave Ovens Logo
82 people viewed this question
Top Welbilt Microwave Ovens Experts
William Miller
William Miller
Are you a Welbilt Microwave Oven Expert? Answer questions, earn points and help others
