Question about Panasonic CT25G7 25" TV
Weird TV the audio is perfect, but the screen vertically squeezes to about a quarter of an inch and stays horizontally regular. it makes it impossible to watch but can still hear whats going on.
    An expert who has answered 500 questions.
  • 556 Answers
The audio is perfect, but the screen vertically squeezes to about a quarter of an inch and stays horizontally regular. it is due to vertical section of your tv has failed. it is a common problem if you are not a tech person call tech to fix it. solution 1 check vertical section supply. 2 check components in vrtical output stage. 3 check vertical output ic. 4 loose contact in vertical section it is not a major ptoblem. good luck.
Posted on Oct 07, 2007
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    Nov 11, 2012 - Uploaded by LUFERQUINT
Jan 26, 2016 | Televison & Video
My JVC tv picture has only one quarter of the screen
Hi. 1/4 screen. Horizontal or vertical ? Makes an important difference. I need more details, like typenumber f.i. Also, you must be able to carry out repairs on this electronic circuitry. Otherwise it makes no sense talking about components etc.
Oct 12, 2014 | JVC AV-27230 27" TV
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
When watching movies on my computer, I am getting a weird line through the middle of the screen at times, also, when things are moving on screen faster, more lines seem to show. I guess they don't really...
i think your vertical IC ( if vertical lines are shown) / horizontal IC ( if horizontal lines are shown) of your monitor has damaged. you may contact a mechanic and change the corresponding IC
Sep 16, 2010 | CTL 261UW 26Inch Wide Screen LCD Monitor...
Ibook screen issues
This is nearly impossible to diagnose via the Web. It sounds like the logic board is at fault, but not necessarily.
Nov 23, 2008 | Apple iBook G4 Mac Notebook
TV problem
Hello Barbara76,
Is this a Horizontal line (inch or two) across the screen, if so
the fault could be either a faulty Vertical IC,Faulty Electrolytic
capacitors or just simple dry joints.
Feb 03, 2008 | Mitsubishi CS-27205 TV
TV video problem
If you have intermittent line horizontally across both tv screens then there is likely to be bad solder connections on the vertical ic's of both of them. This can be fixed by taking the back off with quarter inch nut driver and carefully sliding the chassis out and turning it up to see the solder side. I don't know the location numbers but the vertical ic will be mounted on a metal heat sink and the connections will be in a row. Sometimes you can see the bad connections. You may need a magnifying glass. I recommend someone who has experience soldering electronic circuits. No solder bridges etc. This is for intermittent (works sometimes) problem on vertical ic. If the line stays then the chip ic is bad along with a 1 ohm resistor off the flyback high voltage transformer. From what you described you likely have bad connections. Hope this helps
Dec 30, 2007 | Televison & Video
Video is "Squeezed" and "Choppy"
you have a problem in your vertical circuit i would recomend taking it to your local shop rca's can be real tricky to fix.
May 30, 2006 | RCA 27F530T 27" TV
Panasonic CT25G7 25" TV Logo
95 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
