Question about Konica Minolta PagePro 1350W Laser Printer
Konica Page Pro 1350 - Not printing from DOS
Dear , I have taken new Konika Printer & Installed in my Pc(winxp Sp2) & it is working fine with windows Printing. But I m not able to print from DOS . For Me it is req. Pls advise & help urgently. Vikas
  • Anonymous Nov 16, 2007
    Dear ,'
    I have SQL program , i m not able to take printout from program.
    Printing going to printer & deleted from buffer automaticaly.
    pls update & revert back ..help req.
  • Anonymous Feb 09, 2008
    I am about to break this papgepro 1350, it complicates things alot, help???
    Novelist:
    Scholar:
  • 167 Answers
When you install your printer, you may notice an message asking whether you want to print from DOS based programs. If you answer yes You could print from DOS based programes too. To do this you may need to unistall and re-install your printer again ! If it doesn't work you should download any ultility from the internet to get the printer supported on DOS.
Posted on Oct 06, 2007
  • Deepu Amalan
    Deepu Amalan Oct 06, 2007
    You can download a tool fro the following website to get the job done:
    http://www.dos2usb.com/download.htm
I have a konika minolta751 when i on the machin the oprating system dos not work how can i so0le the problem
which os the machine or your computer. what indications do you have
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 08, 2015 | Konica Minolta Bizhub 751 Copier / Printer...
Hi i have pagepro1300w to be install in windows7. can you advise me with installation?
Despite initial appearances, Windows 7 supports this printer directly.
Click the launch (start) button, and go to devices and printers
add printer
local
Choose the port it's attached to
if the port isn't listed because the printer isn't hooked up, just choose LPT1 for now
Click on Konika Minolta and then click the WINDOWS UPDATE button ****IMPORTANT*** if you don't click Windows update, your printer will NOT be in the printers list.
there may now be 2 Konika Minolta listings on the left, choose the one that has more than 1 printer in it
The papgepro 1300W will now magically be in the list - choose it, and hit next
Follow the prompts and share the printer if you need to, or not if your computer is the only one using it, and on the screen after that, choose whether or not you want this printer to be the default printer
After the driver is installed, if you chose the right port already you can go ahead and print a test page.
If not, don't print a test page, and finish the installation, then plug in the printer - it should come up as new hardware, but now you have the driver for it and it should default to it during the installation.
You will now have 2 copies of the print driver if you didn't have the right port the first time, Either set the new driver as the default, or delete the first one you installed on LPT1: after the installation completes
If you just put the driver in for the right port, go ahead and print a test page.
You're done!
Mar 28, 2011 | Konica Minolta PagePro 1300W Printer
Konica Minolta Pagepro 1350 page count or Print Config sheet?
please go printer utilty option on your pc then you can print a testpage
Feb 10, 2010 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta 1350 printer won't print with Vista
Also try turning spooler OFF/ON. Also, try turning 1350 OFF/ON. Those sometimes work. But 1350 had same problem with W98SE so must be a problem in 1350 software(?). I got so tired of this that I bought a Canon MFC which works perfectly. Still use 1350 to use up the toner.
Sep 15, 2009 | Konica Minolta PagePro 1350W Laser Printer
Endless loop "new hardware found" not installed prop but it is installed and working fine dislogue won't go away
Is this an HP printer? If so check the startup tab in msconfig and uncheck the HP webprinting or print to web (something like that). You can also uninstall the printer and reinstall it to see if that fixes it.
Hope this helps
Apr 21, 2009 | Toshiba Satellite Pro 6100 Notebook
Printer says printer not communicating
Reinstall the drivers or replace your usb cable
Feb 27, 2009 | Office Equipment & Supplies
Printer error message when tried to print test page
You are going to need SP2 to run many applications, doing system restore to before SP2 setup will make SP2 unusable.
If you can install, the printer on a different plug. Uninstall and re-install drivers as suggested on other post, afterward connect printer to new port, drivers will work differently.
You can also try this:
Disconnect printer.
Remove drivers
Uninstall sp2
restart pc
re install SP2
Download and install latest drivers
connect printer
In this way there are less chanches for driver interfeering with sp2. Use last driver version, older drivers may not work well on sp2.
If this had been helpful vote my solution in the other thread. Thanks
Apr 15, 2008 | Office Equipment & Supplies
Konica Minolta PagePro 1350W Laser Printer Logo
467 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
