Question about Zanussi WJS1397W Front Load Washer / Dryer
Cold water wash
What are the settings for cold water washing please? lost the manual
  • 209 Answers
On machines that do not have a variable setting for heat there often isn't a cold wash option, other than pressing the economy button, this does not always give you a cold wash, depend on the make or model without specifying the actual make and model and someone having the original manual its a case of trial end error sometime a search on the internet on the manufacturers web site can offer you a free manual download
Posted on Oct 07, 2007
Inglis refrigerator, model No. 1JT198300
No, This is normal. As the freezer gets cold it also dehumidifies the air in the freezer. There is a drain tube in the bottom of the freezer that directs the water into the basin, where it will evaporate. You should wash the basin every six months and add a little bleach (1/4 cup) when you reinstall the tray. This keeps it disinfected and odorless.
Mar 30, 2014 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Installing a Miele WS5425 cold water fill only?
if you only want cold water for washing, just select cold wash in the program settings and turn off the hot water tap
so the settings you will be looking at are --like --
tub fill ---low water medium water or high water
water temp cold or hot
rinse hot or cold , wash setting --heavy , delicates , whites , woollens etc
may not be exactly worded like that but you get the idea
when ever you see wash temp or water temp , select-- cold
Jul 08, 2017 | Dishwashers
Washed 1997 expedition engine.. now runn ing rough
im not to sure but if washed the engine while the engine was hot u probably cracked the engine block which is a LOT LOT LOT of money to repair. its like throwing very hot plate into freezing water the plate will break into pieces same concept as a hot engine and cold water they dont mix at all
Jul 16, 2012 | 1997 Ford Expedition
My Inglis washer machine (#111-07) which we bought 2 weeks ago, doesn't use any hot water when set to the warm cycle (in between cold and hot), so i can only wash with entirely cold or superhot water...
Hi Elllie602 (!) from retired Englishman in SW France,
2 weeks old? Under guarantee/warantee? Get in touch with the vendor/shop!!!
Even if it takes only cold water for the warm wash (which is a bit daft- normally washers mix the hot and cold accordingly) and heats it, that is not how most hot n' cold washers work.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 21, 2011 | Whirlpool Washing Machines
Reinstalling a washer and dryer and i know which line is hot and which one is cold coming out of the washer ing machine but i dont know which line is hot and which is cold when hooking it back up the the...
If the pipes were installed properly, then the hot is on the left, cold on right.
Hook it up that way, then set it on the smallest load possible, with hot water setting only. If you have hot water filling the basin, you have it hooked up properly.
Oct 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I've just moved house and my machine is not
Hello Friend, I think your machine will work properly if you add a water line splitter. You would connect to the single cold water tap and on the other end you would have two water hoses . Connect one hose to the cold water inlet of your washer and then connect the other hose to the hot water inlet. You can get these at Home Depot. Happy to help, Tim.
Jun 29, 2009 | Whirlpool Washing Machines
Cold water won't stop
You need the water valve to be replaced.:)
Mar 09, 2009 | Whirlpool Inglis IP4400 Washer
Inglis Washing Machine - Heavy Duty Extra Large Capacity
if it doesn't empty check the pump for blockages or just not working electrically, or check cold water supply to machine, or the cold water solenoid, this may also be faulty hope you can find what you need starting from the above, if i have helped please rate me
Oct 04, 2007 | Washing Machines
Zanussi WJS1397W Front Load Washer / Dryer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
