Home | Amana | LWA90A | CHANGING A BELT
Amana LWA90A
Problem for Amana LWA90A
CHANGING A BELT
By jram28 on May 03, 2009
CHANGING A BELT
ON AMANA MODEL # ALW990EAW/PALW990EAW
Same Problem
May 14, 2009
-   I noticed a burning odor and saw smoke come up from the top of the machine. The spin does not empty the water in the tub. Is this problem a result of the drive belt burn and need replacement?
Glenn -   edgelit
Solution #1
posted on May 03, 2009
Not Helpful)
spark9
Rank: Guru
Rating: 86%, 46 votes
To replace a washer belt, remove power, remove back panel. On the left side is the motor, clutch, pump and belt. The pump is driven by a coupler clamped to the pump and clutch assembly. Loosen one of these clamps enough to move the coupler away so the old belt can be slipped past the coupler and also to facilitate the new belt to be installed. The belt runs in a pulley built into the top of the clutch assembly and can be "run" onto the transmission pulley very easily. To adjust the belt tension, pull out the washer, tilt it back against the wall......there are 3 nuts and bolts holding the motor assembly to the bottom frame, loosen these nuts off, the holes on the motor bracket are oval shaped so the motor assembly can be moved back and forth. You can move motor to tighten or loosen the belt, just make the belt fairly snug and don't over tighten it.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Amana LWA90A
Questions and Unsolved Problems for Amana LWA90A
Do you recommend Amana LWA90A?
Answer
Answer
LWA50AW AMANA WASHING MACHINE SPINS BUT DOESNOT AGITATE
Answer
I am getting error code BP on a washer model lwa90aw. What is the cause of this error?
Answer
i have a amana washing mashine. top load and its push button, it says 6 p what does that mean? thank... (More)
Answer
OP code showed up, then it won't agitate. It will spin. Any suggestions? Thanks for your help
Answer
We started with a water leak, repaired that withhub seal kit and new hub, now the machine works well... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Amana LWA90A:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14193
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
