Brandt washing machine error code F04
Machine is totally not working. Once on, it's keep flashing for awhile followed by the error code F04. Help
SOURCE:
  • 38 Answers
SOURCE: Washing Machine Will Not Drain
you have got a blocked filter or pump the filter is located on the right hand side at the front of the machine down the bottom behind the plinth you can drain the water from there as well by pulling the small grey hose out pull the plug out of the end and place in a small bowl good luck when the water is out you can check the pump impeler as well clean the filter houseing and put it back all should b well unplug the machine b4 u start work
Posted on Sep 04, 2007
SOURCE: Bosch Washing machine broken, flashes
We keep getting this but can get around it.
You probably have a blocked pump/filter. If there is still water in the machine you will need to drain this first. So...
First try this. If it's finished the washing phase turn off the machine (rotate the dial to off then turn off at mains), leave for a min and turn on again at mains, then move dial to the rinse cycle.
If this works then it may clear the blockage for you. If not go to the bits below.
1. Remove the covering from the bottom RHS of the machine
2. There is a small black hose. Pull out and place in suitable container/bucket then unplug the end.
3. Will take quite a while to remove all the water. (Tip - once water is well below the window level unlock door and remove washing).
4. Once all water removed replace hose top and unscrew anticlockwise the white holder to the right of the hose. Make sure you have a towel handy to mop up any excess water.
5. Remove and clean all junk from it under a tap.
6. Look and see inside hole if any debris wool/cotton etc is blocking impeller and remove if necessary.
7. Replace holder.
et voila it should work again!
If not you have probably have a blockage somewhere in the pipe inside the machine. Sorry can't help with that one.
Posted on Jan 30, 2009
SOURCE: Baumatic BTWM6 washing machine flashing F02 error
hi, you need to empty the filter, ours does the same all too often. The filter is located bottom right of the machine at floor level, which is rather daft for an integrated applicance; we have to remove a whole length of plinth to empty ours. Be warned, a lot of gunge and water will come out so have towels at the ready, especially if you have a laminated floor. Turn the white slot with a a 10p piece......and empty. Not the most pleasant of jobs, but effective. Good luck!
Posted on Mar 18, 2009
nick75666
SOURCE: washing machine error code f04
ok these machines are great and they make it very simple F04 means cant drain which usually means money or bits and bobs stuck in pump impeller. On the front of the machine remove the bottom right hand plastic cover by hand this is where the access to the filter and pump can be found, you will see a black cap about 3" which can be unscrewed you may need pliers or something to grip it and turn it, have plenty of old towels ready as the water in the machine will begin to come out when you unscrew it(anti clockwise), just unscrew it a little until the water trickles out and mop it up with the old towels until the water stops then continue to unscrew anti clockwise until you are sure the thread is no longer gripping you cant over unscrew so if in doubt just keep unscrewing....then it needs to be pulled out toward you, you will probably need grippers or pliers for this just wiggle it out and remove it, look inside you will see the drain pump impeller, put a finger in and feel for whatever is obstructing it and remove, now use a finger to feel for the inlet that comes into the chamber from the left, use a finger to feel inside this pipe and remove other bits and bobs in the pipeline that were ready to find there way to the pump, once you have removed whatever is in there clean with a rag the thread and scale and make it nice and clean. In your sink wash the screw cap and little white filter piece that is attached to the cap and careful so as not to cross thread it push and then screw it back in making sure the filter solid plastic part is facing toward the inlet pipe you cleaned earlier as its that solid part that prevents (should prevent but didn't or you wouldn't be doing this) large objects finding there way in to the impeller chamber, screw the cap in and restart the cycle and your done, easy repair anyone can do it..... Don't forget to send me your luv if this works for you!!... Nick (at) 2xx.co.uk
Posted on Apr 27, 2009
jonniewalker
  • 1031 Answers
SOURCE: f04 error message on a bosch exxcel 1400 washing
This error indicates an obstruction in the water pump. . Tip machine back so you can fit a bowl under the bottom right hand side. Flip back cover at bottom right to reveal pump filter access - unscrew (quite a bit of water comes out so have the bowl ready).
Posted on Sep 26, 2009
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
Brandt WFK1458FE ERROR CODE F08
go to http://www.brandt.com/ and get the support via ONLINE via chat or phone.
God bless you
Sep 25, 2012 | Washing Machines
Indesit washing machine wixe127 has f04 faultcode starts cycle then empties and fills simultaneously
Error code F04 indicates pressure switch jammed on empty.
to rectify, do the following
Remove lower rear panel of washer.
Remove large black hose on drum
Remove and clean filter inside hose.
Remove hose onto pump and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Washing Machines
Hi my washing machine bosch exxcel is not working ive checked filter the code f04 keeps flashing and i cant find my hand book to check code do you know what it means
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 03, 2009 | Washing Machines
Hotpoint wt965 f04 error
F04 indicates that the pressure switch is jammed on empty,
check that the pump is working o/k, if it seems o/k and it drains o/k, then you have no alternative than to call an enginner
This really is your only option.
Plz rate my solution
Thanks.
Dec 18, 2008 | Hotpoint Ultima WD72 Front Load...
Bosch 1400 exxcel
The machine thinks the drain is blocked.. check the pump and outlet pipe for buildup of dirt.
I noticed holding start down for several seconds whilst powering the machine on, then turning it off / then on again would clear the machine's idea of where it was during a program. Does this affect the error code you're seeing?
May 26, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
BOSCH 1400 excell
find the punch hole on plate use pointed object stick in hole and turn
Oct 05, 2007 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
1,244 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
