Question about Logitech Premium Headset
Logitech headset - sound
The microphone works well and I can hear the background sound of music incl backing vocals - but cant hear the front voice of melody. used to work well? have disconnected to use inbuilt speakers and have connected voice recognition within vista recently ? these have affected sound. how do I fix it?
  • Effyness Apr 21, 2009
    I just bought this Logitech USB headset a few days ago. I can hear sound out of both speakers, but when I listen to music, I can only hear the background music and background vocals. I can't hear the front vocals. It used to work momentarily if the wire was positioned a certain way, but now, I can move the wire all I want and it still doesn't work. Any help?
Me too! but I am using XP
Posted on Dec 18, 2007
SOURCE:
I hear my own voice when I talk on Logitecs H600 wireless headset
IF you are in Windows 7: -
1. Click "Control Panel" > "Sound" > "Recording"
2. Place cursor over "Microphone - Logitech Wireless Headset Default Device".
3. Right Click and select "Properties"
4. Click the "Listen" Tab
5. Uncheck the "Listen to this device"
6. Click "Apply",. and "OK"
That will eliminate you hearing any nose picked up by the microphone. Others will still be able to hear your voice as long as you have the headset as your default microphone.
Mar 02, 2013 | Logitech (980408) Wireless Headset
Logitech headset problems
the problem is with cable(wire)...the insulation got failed nd got short circuited....if warranty period is there u can get it replaced with a new one...
Apr 05, 2010 | Logitech Premium Headset
My microphone will not work after buying a new keyboard
look at you Sounds & Audio Devices under the Control Panel, go to the Voice Tab and pick your Default Device to use as your Voice recorder
Aug 17, 2009 | Logitech 967437-0403 Keyboard
Logitech ClearChatStyle Headset + Skype + Vista Premium Home
Vista always has sound card problem.
I had too because with my headset (microphone) It works through your sound card
but it works well now after I installed it as below
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-78911-1
ADI SoundMAX Integrated HD Audio Driver for Windows Vista
Hope can help
Aug 15, 2009 | Logitech ClearChat Stereo Headset Headset
People can hear background noises on my PC but not my voice
Perform some simple steps as follows.
1. Double click on the volume control icon in the system tray, that is on the right hand bottom side of the screen. Check if the microphone is muted.
2. Right click on the same icon, and select "adjust audio properties." You will now get a window that says Sounds and Audio Devices Properties. Click on the tab named voice on top of that window, and check what is selected as the voice recording device. Check in the drop down menu to change the device and use the "test hardware" option to test the mic.
3. Make sure your microphone is working fine. Other people are not hearing your music from your microphone, but from your system itself.
Get back if you have additional questions.
Jun 15, 2009 | Logitech 250 Headset
Can't hear voice of singer on speakers, more of an echo sound
An old trick to remove vocals from a song was to rip the right channel, then the left, the combine them (since vocals are typically mixed in a third 'center' channel, though things like reverb or echo are applied to the right and/or left channels which sounds like what you are hearing).
I would play with the balance and mixer settings and see if you can get the vocals back. Also try other speakers or even headphones and see if you have the same problem.
Hope this helps!
May 28, 2009 | Bose Companion 3 Computer Speakers
How to hear my voice through my usb microphone?
by default the playback of your voice is muted. next to your clock theres the sound speaker icon click on it, you should see microphone somewhere there, if you dont press settings from the toolbar and then properties
then on the playback make sure there is a X on microphone.
then click ok, now check is the microphone muted? unmute it and speak to the microphone you should hear your own voice played back instantly from the speakers.
Apr 24, 2008 | Logitech USB Desktop Consumer Microphone
Logitech headset, new vista operating system
either the headset is not supported by Vista, or you need to right click on both speaker icons, normally coloured red and black and in the properties you need to see if your headset is listed as one of the microphone input devices, if you need to make the Logitech headset the default mic and not the windows generic mic. If you do not see it in the properties then it may not be recognised by Vista.
Aug 13, 2007 | Logitech Internet Chat Consumer Headset
No vocals!
Maybe your headphones are pulled out halfway.
Feb 11, 2007 | SanDisk Sansa m240 MP3 Player
Logitech Premium Headset Logo
273 people viewed this question
Top Logitech Radio Communications Experts
Ekse
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
