Question about Canon PIXMA MP830 All-In-One InkJet Printer
Canon PIXMA MP830 is not able to recognize cyan
I have a U043 saying the cyan ink cannot be recognized after I was trying to replace it with a new one. I did accidently put the blue on there & the cyan in the blue than the printer did not recognize both at first, but after I switched it, the blue was recognized and the cyan still did not work. Than I had went back to return the new cartridge at the store with another one and it still did not work with the new one. Do I need to clean the cyan area? And how?
  • 1 more comment
  • deb63 Feb 12, 2008
    Unlike Maritess, I did not place my ink tanks in the wrong position. All was working fine until one day I started receiving these error messages every time I attempted to print or copy: 1. Magenta ink tank not recognized, or 2. There is more than one of this type of ink tank installed. All I do is open the printer, pop out the Magenta ink tank and pop it back in. Sometimes I have to do this more than once, but it always works eventually. It's getting to be a pain, though, to have to open, pop out, pop in every time I want to print or copy. What's going on with this?
  • TinyShadow Feb 14, 2008
    I have the same problem as deb63 except that it is the yellow. I get 3 messages. 1. yellow ink tank not installed properly 2. yellow ink tank not recognized or 3. more than one yellow ink tank installed. The messages dont display in any certain order, as far as which one gets displayed first. I usually have to remove it and put it back in several times before it will stop giving messages and finally print. This is did not start happening right after ink replacement. In fact, the cover had not been lifted for 2 months prior to this happening and then the only reason it was lifted was to fix this issue. (not fixed, still happening) Why were there no problems for so long and now all of a sudden I am having these issues with an ink tank that has been working fine?
  • Anonymous Feb 16, 2008
    In my case, this message started wit the Black ink, then moved to other cartridges, sometimes more than one. Its most annoying. I've been removing and replacing the offending cartridge(s) each time until the alarm light goes off but it always comes right back after a while.
Same\
Posted on Jul 23, 2008
SOURCE:
Cyan ink cartridge is flashing, only prints in blue.
Hi cmwierson, I would suggest you update your printer drivers, try this, follow instructions exactly as written:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop(watch for the light yellow bar at the top of window viewing pane, click on this and choose – download file - . Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Oct 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
MP500 ink tank cannot be recognized error U043
I had the same problem. My mp630 is also only 4 months old. I replaced all colour ink cartrdiges(inc black), but was only able to release the function for detecting the ink levels for magenta and cyan. Yellow and black then started giving error message U043, with them alternating between working, but never working at the same time. Getting them all clicked in with the lights glowing red does not solve the problem, as once the printer cover is closed, the same error message turns up. The only thing that worked for me is moving the chip slightly out of alignment, by pushing the sliding chip holder, and I only had to do this twice before they all started working and the printer was unlocked.
Jul 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Error U043 - Ink Tank Cannot be recognized
Try to open and close the main cover a bit, ... ink recognition will start and may solve the probleme ...
... otherwise remove the cartridge and clean the chip contacts e.g. with spirit
Maybe also pressing the stop/reset-button for >10s will also help to continue printing, but in this case the fill level of the cartridge will no longer be shown
Apr 26, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Same problem - two solutions I found helped me work out mine. One said contacts needed to be cleaned and it worked to use a Q-tip and alcohol or just click it in position several times until it recognizes the cartridge - this may work. Another said that they got it to work by installing a brand new cartridge - cool, but I have one full of ink it won't recognize. So I pulled the little circuit board off a used cartridge (like you need to do with some refills) and put it on the cartridge that it wouldn't recogrnize - works great. Still haven't figured out how to get it to acknowledge ink levels though. Canon really should be more consumer friendly since these problems seem to be intended to compel the use of proprietary cartridges.
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
I have a canon mp510 pixma same message U043 and a u150 fault.
I cant see any chip to replace and have replaced my original cartridges with a non branded cheaper type, this might be why. Does this make a difference or is this the same problem occurring with replacement canon cartridges as well.
Dont want to buy genuine ones if its not going to make any difference.
Anyone who can help me would be appreciated
Nov 14, 2007 | Office Equipment & Supplies
I had the u043 problem on the blue cartridge on my mp830.
I was using non-original replacement inks but re-using the chips from the originals - replacing the blue cartridge would cause it randomly work but i then noticed the chip holder was not centred so I realigned it and hey presto! the problem was solved first time.
Sep 17, 2007 | Canon Pixma MP500 All-In-One InkJet...
Ink Cartridge Error PIXMA MP830.
pleaz clean the cartridge sensor and also align cartridges by program in your manual
Sep 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
219 people viewed this question
Clive
Clive
old marine
old marine
Ekse
