Home | Panasonic | KX-TM80B Digital Answering Machine | Answering machine qui...
Panasonic KX-TM80B Digital Answering Machine
Problem for Panasonic KX-TM80B Digital Answering Machine
Answering machine quit working on a KX-T30810 system
By donbergert on May 03, 2009
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I have a KX-T30810 EASA-PHONE system using Panasonic phones. One phone jack was configured for a 2-wire answering machine with a cordless phone along with the Panasonic phone. It used to work perfectly but about a month ago the answering machine quit recording and I can no longer make calls on the cordless phone. When you press 'talk' on the cordless phone, you get what sounds like a busy signal. I can receive calls on the cordless phone though. If you unplug the Panasonic phone the cordless phone and answering machine work fine. It will just no longer work with both phones on the same jack. I suspect the 'program' switch got put in the 'program' mode for that phone and caused something to get messed up.
Does anyone know what needs to be reprogrammed on the local Panasonic phone to allow both the phone and answering machine to work on the same jack?
Thanks,
Popular Solutions for Panasonic KX-TM80B Digital
Questions and Unsolved Problems for Panasonic KX-TM80B Digital
Do you recommend Panasonic KX-TM80B Digital Answering Machine?
Answer
Answer
We have an Easa-Phone KX T-30865. It stopped working when you push the call button on the outside... (More)
Answer
How do I disconnect an extension in order it shouldn't ring but still be able to answer the door... (More)
Answer
I need to add an answering machine . I was using an old bell unit that allowed me to record several... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic KX-TM80B Digital...:
Top Answering Machine Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Answering Machine Experts
Top Telephone Repair
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
(316) 262-7171
Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
