Question about HP DeskJet F380 All-In-One Printer
Not printing Printer lights all on. Connected to laptop. Was working a few days ago now I get a message USB not recognized. Have tried putting it into other ports but still nothing. I don't have the software to reload. What can I do. It's only 4mths old but I am living in another State and in a very rural community.
    President:
  • HP Master
  • 2,022 Answers
Just remove all the usb devices form your device manager and restsr your laptop and let the system automatically detect .
Posted on Oct 06, 2007
6ya staff
SOURCE:
Printer keeps saying busy printing another document
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Feb 10, 2012 | Lexmark X4580 InkJet Printer
My HP Deskjet F380 has the latest printing software installed; it spools and is attached to my laptop in the correct USB port; but it doesn't print. The message is "no connection." It printed...
Verify that the USB connection is fully inserted in the back of the printer itself. If all is well there, try to think if you've run any updates on your laptop recently, or installed any new software that could be conflicting. If yes, try removing the new software or recent updates, and try a test print. If this still does not work, try disconnecting the printer, powering down your machine, starting it back up and then reconnecting the printer to the USB port. Sometimes you have have a glitch in the USB port that causes your computer to stop recognizing a device seemingly out of nowhere. If none of the above seems to help, it might be as simple as a USB cable that's become faulty. Hope this helps!
Nov 19, 2010 | HP DeskJet F380 All-In-One Printer
I have a canon ip6700d (using windows 7 64bit). I have had this printer about 3 years. Used it fine 2 days ago and today it will not print but gives USB error 43 and gives messages saying " usb device not...
There can be some situations when the printer installer will not work on the computer. Sometimes there is a fault in the CD or sometimes there is a fault within the program. In any case, the printer can still be installed on the computer using the Add Printer Wizard feature of Windows. The wizard lets you choose the port where the printer will be connected as well as other settings of the printer. or get more help from here . Hope this helps you.
Oct 22, 2010 | Canon PIXMA iP6700D InkJet Photo Printer
A few days ago, my computer started giving me the message "USB Device Not Recognized", and I soon realized it referred to my PIXMA MP160 printer/scanner. I've tried almost everything including reloading...
Try disconnecting unit from USB port, restart computer, and reinstall unit. Might try another USB port on computer. It also may be a bad printer/scanner! Try it on another computer.
Jul 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Light is blinking, doesnt print, it prints before but now it doesnt. appears online and ready on the computer.
If the port had been changed to LPT1 the printer will not work.
LPT1 is the large parallel port, while you are using USB on this printer.
the red light came on probably because of a jam , or because of one of the documents in the printer cue.
The easiest thing to do is
Unplug printer usb.
Go to control panel>installed printer.
Delete all the instances of this printer from there and chose to delete drivers if asked.
Reistall the printer using the printer disk, plug in printer data cable only when asked by setup wizard.
If you have a different USB cable, also use it, just in case.
If that does not fix the problem , then there is an internal fault in the printer.
Regards.
Jun 01, 2009 | HP DeskJet D1460 InkJet Printer
Communication problem with printer over Airport, i.e. won't print
try uninstalling & reinstaling the printer will only work...
Apr 25, 2009 | Office Equipment & Supplies
Usb malfunction
The USB ports have gone bad. Just because they show up in device manager as being recognized does not mean they are working correctly. They are controlled by chips onthe motherboard and if one of those chips has gone bad, then they just won't work. The cheapest solution would be to purchase a USB card and install it, bypassing the onboard ports. Thanks and please take a moment to give this solution a rating of fixya. Thanks! :c)
Dec 29, 2008 | Intel Motherboard
Can't print to mac wirelessly (could do it a few days ago)
I had the same problem until recently. You have to install the drivers FROM THE CD that came with the printer, instead of selecting the drivers from the default list. Then, when selecting which printer driver to use (you'll have two options) choose Canon IJ and NOT Canon MX310 series. This is a problem with their MX310 driver, which is solved using a default/generic Canon InkJet (hence, the IJ) driver. Hope this helps!
P.S. This only works on Mac OS X. I have yet to figure out how to print wirelessly through Vista. Will keep you posted.
Mar 28, 2008 | Canon PIXMA MX310 All-In-One Printer
Cannot connect
have your tried removing the driver and reinstalling? sounds like a corruption to me.
been struck by lightening / power surge?
anything funky in the computer's behaviour three days ago, but not related to priner?
Mar 24, 2008 | Epson Aculaser C1100 Printer
Cannot print from Lap top using usb adapter to cannon printer.
It sounds that your problem might be on the USB to paralel adapter. Do you have another printer ti try it with ? Check the configuration for this adapter.
Good luck
Nov 18, 2007 | Samsung SCX-4100 All-In-One Laser Printer
HP DeskJet F380 All-In-One Printer Logo
118 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
