Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Sound problems on PT 50LC13
The sound doesn't work on my PT-50LC13. I've had problems with the lamp before (like many others), but this is the first time the sound hasn't worked. I haven't found another post on this topic.
  • 59 Answers
Try unpluging and plug back in, same on cable box if you have one i have had calls with no sound and found cable box is the problem just unplug for about 30 sec and plug back in
Posted on Oct 23, 2007
Panasonic pt-50lc13 won't show picture. Blinks green when turned on can hear lamp clicking then goes off to red blinking for a few miniutes then shuts down to just red . Can u help me out please?
sound like your lamp is bad ...Panasonic TY-LA1000 Lamp Replacement...Ballast Repair Kit for Panasonic PT-50LC13 some time the ballast go bad as well to hear bouth part number one lamp and 2 ballast I hope this help you..
Nov 19, 2013 | Televison & Video
Panasonic PT-50LC13 50 blinks 8 times at power button
hi, make sure the lamp is fitted securely and the lamp cover as well you may need to reset the lamp counter hope it helps
regards
shaun
Nov 27, 2011 | Panasonic PT-50LC13 50" Rear Projection...
I replace lamp on PT 50LC13 50 and still no picture or sound...could it be the ballst
Hello
It is a common fault to this model that ist ballast may get damaged,. Just replace it. If you stll do not get the problem rectified, inform me. I've its service manual [not user manual] in which all repair work has been explained with illustrations. All adjustments should be done, disassembling and reaseembleing etc. Byt I can't send that document diret to you by this site, as this Fixya new site does not allow any PDF files to upload by it. You have to buy one amoung my services advertised in Fixya site. You can also come to me and purchase my service, bt typing my nick name "gopakumarg43" on Google search box, and clik on 'Gopakumarg43-fixya' there. You can access my services publshed there by Fixya, and can select the apprpriate. When you purchase it, Fixya will give alert, and one link between us, through which we can communicate each other till yourTVs problem has been rectified. OK.
Nov 11, 2011 | Panasonic PT-50LC13 50" Rear Projection...
TV shut off and cannot turn back on
If your tv is around 2-4 yrs or used 6000-8000 hrs,never replaced the lamp before it could be time to replace it.The other most common failure is the board that powers the lamp,which is called the ballast.When its bad it will make a clicking sound or like wanting to turn on.The part # for your lamp is TYLA1000 you can find it here:http://www.discount-merchant.com/Panasonic-TY-LA1000-Lamp-DLP-TV-bare-lamp-p/panasonic-ty-la1000-lamp.htm Good luck and God bless you!
Feb 10, 2010 | Panasonic PT-50LC13 50" Rear Projection...
NEW BULB INSTALLED FOR PANASONIC PT-50LC13 TV STILL NO LIGHT
close lamp door set will not work with door open. if not that listen for arcing sound in back if  don't hear that bad ballest
Jun 09, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Reset Time Problem on Panasonic TV (PT-50LC13)
Power on the set, listen for afaint buzzing sound as the set tries to fire up. If you do not here it then your lamp driver, or ballast is most likely faulty. Also make sure you have the door and all covers back in place and secure. And make sure you insatlled an orginal panasonic lamp because some generic will not work.
Jan 06, 2009 | Panasonic PT-50LC13 50" Rear Projection...
PT 50LC13. Sound but no picture
Unplug the set fro about a minute or two and see if that clears the error. If you are using a surround amp that yoir video sources pass through before it gets to the tv then make sure that is set to the right input and working properly and finally make sure the source providing the signal is working. If all is good then you have an issue on your main board where the video switching is processed.
Jan 01, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panny pt-50lc13 steady amber flashing light
Sounds like a defective lamp diever or ballast.Listen for a buzzing sound when you turn the set on. If you do not hear it then most likely you have a bad ballast or lamp driver. Worst case scenerio would be the engine itself.
Dec 28, 2008 | Panasonic PT-50LC13 50" Rear Projection...
PT-50LC13
It could be the ballast that is bad. A bad ballast also shortens the Lamp life .
Jun 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
74 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
